    UNSOLVED Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    Raspberry Pi App Software
    1237
      veye_xumm @jambojettt last edited by
      @jambojettt
      uname -a
      ls /usr/lib/modules/
      • J
        jambojettt @veye_xumm last edited by
          @jambojettt
          Sorry for reply late.
          • J
            make
            reinstalled by github
            Which one do I use?
              @jambojettt
              • J
                  @jambojettt
                  dmesg | grep veye
                  • J
                    @veye_xumm nothing showed
                    • J
                      @veye_xumm is there any point in a fresh pi os install?
                      I accidentally swapped the pins after I checked everything, and it shorted, hope it works.
                      I just need it to work, so I can do my thesis on argicultural application of machine learning.
                      • J
                        Everything is the same
                        • J
                          @veye_xumm a926f7d9-25bb-40db-bc6d-d6136c0cddd9-изображение.png fc72b201-eabf-40b3-81b9-de8a99077f4b-изображение.png !438d2092-5f6a-460e-b2b2-438605356263-изображение.png [0_1764333202538_7825037f-a24a-4cbf-b16b-42693c1e5a87-изображение.png](Uploading 100%)
                          I'm out of possible problems, maybe i got the pins wrong.8c38bbeb-7f2c-423a-bb4c-546227c6c1ea-изображение.png
                          • J
                              @jambojettt
                              I suspect you haven't seen the most important document, which is the link below. Generally, you don't need to compile the driver yourself. Instead, you can simply install the driver by following part4 in the link below. Specifically, the command you need to execute is: sudo ./install_driver.sh veyecam2m
                              https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi#Driver_Installation
