<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[buildme failed]]></title><description><![CDATA[<p dir="auto">Hi, I installed all libraries for python. I run the <em><strong>./buildme</strong></em><br />
with errores.</p>
<pre><code>tga.c: In function ‘load_tga’:
tga.c:103:53: warning: comparison of integer expressions of different signedness: ‘size_t’ {aka ‘unsigned int’} and ‘int’ [-Wsign-compare]
 103 |                     if (fread(image, 1, buflen, fp) != buflen) {
RaspiCamControl.c:201:4: warning: missing initializer for field ‘num_parameters’ of ‘COMMAND_LIST’ [-Wmissing-field-initializers]
 201 |    {CommandStatsPass,   "-stats",     "st", "Force recomputation of statistics on stills capture pass"},
In file included from RaspiCamControl.c:42:
RaspiCLI.h:38:8: note: ‘num_parameters’ declared here
  38 |    int num_parameters;
RaspiCamControl.c:204:4: warning: missing initializer for field ‘num_parameters’ of ‘COMMAND_LIST’ [-Wmissing-field-initializers]
 204 |    {CommandStereoDecimate,"-decimate","dec", "Half width/height of stereo image"},
RaspiCamControl.c:205:4: warning: missing initializer for field ‘num_parameters’ of ‘COMMAND_LIST’ [-Wmissing-field-initializers]
 205 |    {CommandStereoSwap,  "-3dswap",    "3dswap", "Swap camera order for stereoscopic"},
RaspiCamControl.c: In function ‘raspicamcontrol_set_ROI’:
RaspiCamControl.c:1468:4: warning: missing initializer for field ‘rect’ of ‘MMAL_PARAMETER_INPUT_CROP_T’ [-Wmissing-field-initializers]
1468 |    MMAL_PARAMETER_INPUT_CROP_T crop = {{MMAL_PARAMETER_INPUT_CROP, sizeof(MMAL_PARAMETER_INPUT_CROP_T)}};
In file included from /usr/include/interface/mmal/mmal_parameters.h:32,
                from /usr/include/interface/mmal/mmal_port.h:42,
                from /usr/include/interface/mmal/mmal.h:357,
                from RaspiCamControl.c:36:
/usr/include/interface/mmal/mmal_parameters_camera.h:594:28: note: ‘rect’ declared here
 594 |    MMAL_RECT_T             rect;    /**&lt; Crop rectangle as 16P16 fixed point values */
RaspiCamControl.c: In function ‘raspicamcontrol_zoom_in_zoom_out’:
RaspiCamControl.c:1497:29: warning: comparison of integer expressions of different signedness: ‘int32_t’ {aka ‘int’} and ‘long unsigned int’ [-Wsign-compare]
1497 |         if (crop.rect.width &lt;= (zoom_full_16P16 + zoom_increment_16P16))
RaspiCamControl.c:1511:28: warning: comparison of integer expressions of different signedness: ‘unsigned int’ and ‘int32_t’ {aka ‘int’} [-Wsign-compare]
1511 |         if (increased_size &lt; crop.rect.width) //overflow
RaspiCamControl.c: In function ‘raspicamcontrol_set_annotate’:
RaspiCamControl.c:1609:7: warning: missing initializer for field ‘enable’ of ‘MMAL_PARAMETER_CAMERA_ANNOTATE_V4_T’ [-Wmissing-field-initializers]
1609 |       {{MMAL_PARAMETER_ANNOTATE, sizeof(MMAL_PARAMETER_CAMERA_ANNOTATE_V4_T)}};
/usr/include/interface/mmal/mmal_parameters_camera.h:798:16: note: ‘enable’ declared here
 798 |    MMAL_BOOL_T enable;
D_mipicam.c: In function ‘encoder_buffer_callback’:
D_mipicam.c:610:19: warning: unused variable ‘new_handle’ [-Wunused-variable]
 610 |             FILE *new_handle;
D_mipicam.c:598:11: warning: unused variable ‘bytes_written’ [-Wunused-variable]
 598 |       int bytes_written = buffer-&gt;length;
D_mipicam.c: In function ‘D_start_yuv_stream’:
D_mipicam.c:845:89: warning: unused parameter ‘userdata’ [-Wunused-parameter]
 845 | int D_start_yuv_stream(CAMERA_INSTANCE camera_instance, OUTPUT_CALLBACK callback, void *userdata)
D_mipicam.c: In function ‘capture_buffer_callback’:
D_mipicam.c:921:8: warning: unused variable ‘complete’ [-Wunused-variable]
 921 |    int complete = 0;
D_mipicam.c: In function ‘D_capture’:
D_mipicam.c:1184:20: warning: unused variable ‘time’ [-Wunused-variable]
1184 |    struct timespec time;
D_mipicam.c: In function ‘D_get_support_formats’:
D_mipicam.c:1327:12: warning: unused variable ‘pcamera’ [-Wunused-variable]
1327 |  DCAMERA * pcamera = (DCAMERA *)camera_instance;
<p dir="auto">Someone could help me?</p>
]]></description><link>http://forum.veye.cc/topic/682/buildme-failed</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 10:56:37 GMT</lastBuildDate><atom:link href="http://forum.veye.cc/topic/682.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 08 May 2025 05:03:55 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to buildme failed on Thu, 29 May 2025 04:08:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> Thanks! I'll read and reinstall the SO.<br />
Hopefully, I'll be able to show if the problem is resolved in the next few days.</p>
]]></description><link>http://forum.veye.cc/post/4776</link><guid isPermaLink="true">http://forum.veye.cc/post/4776</guid><dc:creator><![CDATA[Israel_bolo]]></dc:creator><pubDate>Thu, 29 May 2025 04:08:23 GMT</pubDate></item><item><title><![CDATA[Reply to buildme failed on Wed, 21 May 2025 09:52:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/israel_bolo" aria-label="Profile: israel_bolo">@<bdi>israel_bolo</bdi></a> Actually, for the development of new projects, I would recommend using the V4L2 mode, which is the material from the link below.<br />
<a href="https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi" rel="nofollow ugc">https://wiki.veye.cc/index.php/V4L2_mode_for_Raspberry_Pi</a></p>
]]></description><link>http://forum.veye.cc/post/4775</link><guid isPermaLink="true">http://forum.veye.cc/post/4775</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 21 May 2025 09:52:49 GMT</pubDate></item><item><title><![CDATA[Reply to buildme failed on Wed, 21 May 2025 02:22:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a> I'm using 64 bits piOS.<br />
I'll change the version and reinstall</p>
]]></description><link>http://forum.veye.cc/post/4774</link><guid isPermaLink="true">http://forum.veye.cc/post/4774</guid><dc:creator><![CDATA[Israel_bolo]]></dc:creator><pubDate>Wed, 21 May 2025 02:22:04 GMT</pubDate></item><item><title><![CDATA[Reply to buildme failed on Wed, 21 May 2025 00:59:58 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/israel_bolo" aria-label="Profile: israel_bolo">@<bdi>israel_bolo</bdi></a></p>
<p dir="auto">May I ask which version of piOS you are currently using? The libdmipicam mode is only suitable for the 32-bit legacy mode of piOS.</p>
]]></description><link>http://forum.veye.cc/post/4773</link><guid isPermaLink="true">http://forum.veye.cc/post/4773</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Wed, 21 May 2025 00:59:58 GMT</pubDate></item><item><title><![CDATA[Reply to buildme failed on Tue, 20 May 2025 04:15:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/veye_xumm" aria-label="Profile: veye_xumm">@<bdi>veye_xumm</bdi></a><br />
I continued with the next lines:</p>
<pre><code>./buildme
<pre><code>sudo install -m 644 ./libdmipicam.so /usr/lib/
<p dir="auto">The <em><strong>usr/lib</strong></em> directory I have the next files:</p>
<pre><code>apt                   firmware                              libBLT.2.5.so.8.6            libresid-builder.so.0.0.1  openssh               rp-prefapps
arandr                gcc                                   libBLTlite.2.5.so.8.6        libRTIMULib.so             os-release            rsyslog
arm-linux-gnueabihf   girepository-1.0                      libdfalt.so.0                libRTIMULib.so.7           p7zip                 runit-helper
arm-linux-musleabihf  git-core                              libdfalt.so.0.0.0            libRTIMULib.so.7.2.1       pam.d                 sasl2
aspell                gnome-session                         libdmipicam.so               libsidplay2.so.1           piclone               sftp-server
bfd-plugins           gnome-settings-daemon-3.0             libgdal.so.28                libsidplay2.so.1.0.1       pipanel               ssl
binfmt.d              gnupg                                 libgdal.so.28.0.2            libsigc-1.2.so.5           pkgconfig             sudo
blt2.5                gnupg2                                libhardsid-builder.so.0      libsigc-1.2.so.5.0.7       pkg-config.multiarch  sysctl.d
chromium-browser      gold-ld                               libhardsid-builder.so.0.0.1  libsupp.a                  pm-utils              systemd
compat-ld             groff                                 libident.so.0                libvpf.so.4                policykit-1           sysusers.d
console-setup         gui-pkinst                            libident.so.0.22             libvpf.so.4.1              pppd                  tasksel
cpp                   gvfs                                  libmfhdfalt.so.0             locale                     printer-driver-escpr  tc
crda                  ifupdown                              libmfhdfalt.so.0.0.0         lsb                        pulse-14.2            tcltk
cups                  init                                  libogdi.so.4                 lxinput                    pypy                  terminfo
dbus-1.0              ispell                                libogdi.so.4.1               lxplugins                  python2.7             thunar-archive-plugin
debug                 jni                                   libpigpiod_if2.so            man-db                     python3               tmpfiles.d
dhcpcd                kernel                                libpigpiod_if2.so.1          menu-cache                 python3.9             udev
diet                  klibc                                 libpigpiod_if.so             mime                       qpdfview              udisks2
dpkg                  klibc-krh8Sgsh8PW7Qbsa0KsFm65rfDw.so  libpigpiod_if.so.1           modprobe.d                 raspberrypi-net-mods  userconf-pi
emacsen-common        ld-linux-armhf.so.3                   libpigpio.so                 modules                    raspberrypi-sys-mods  valgrind
environment.d         ld-linux.so.3                         libpigpio.so.1               modules-load.d             raspi-config          vnc
file                  libarmadillo.so.10                    libpypy-c.so                 NetworkManager             rc-gui                X11
firewalld             libarmadillo.so.10.1.2                libresid-builder.so.0        ogdi                       resolvconf            xorg
<p dir="auto">I compiled but when I executed any file in the <em><strong><strong>python_demo</strong></strong></em> directory I have the next error:</p>
<pre><code>Load libdmipicam fail
<p dir="auto">I appreciate the answers</p>
]]></description><link>http://forum.veye.cc/post/4770</link><guid isPermaLink="true">http://forum.veye.cc/post/4770</guid><dc:creator><![CDATA[Israel_bolo]]></dc:creator><pubDate>Tue, 20 May 2025 04:15:26 GMT</pubDate></item><item><title><![CDATA[Reply to buildme failed on Thu, 08 May 2025 05:37:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/israel_bolo" aria-label="Profile: israel_bolo">@<bdi>israel_bolo</bdi></a><br />
I see some warnings, but no errors. could you please continue and see if it compiles?</p>
]]></description><link>http://forum.veye.cc/post/4762</link><guid isPermaLink="true">http://forum.veye.cc/post/4762</guid><dc:creator><![CDATA[veye_xumm]]></dc:creator><pubDate>Thu, 08 May 2025 05:37:39 GMT</pubDate></item></channel></rss>
