    SOLVED Hardware Triggering for the CS-MIPI-SC132
    3040
    • E
      ess last edited by
      Thanks for your reply @veye_xumm and sorry for the late answer.
      So we got a fix with our first problem regarding the notifications.
      But we are stuck with the Nvidia trigger issue. We are using Nvidea Jeston Nano.
      We have stumped upon an example from Allied Vision, but they seem to solve the problem within theyer camera driver.
      How have you attempted to fix this issue? Do you thin it is fixable for us without touching the camera firmware? Or do we need your Help with this?
      Thank you many thanks in advance!
      Greetings ess
      A small side Note:
      Ther is a typo in the CS-MIPI-SC132 I2C.sh user guide at the Trigger denounce section. The listed code is:
      ./cs_mipi_i2c.sh -w -f triggeredge -p1 enable -p2 [value]
      ./cs_mipi_i2c.sh -r -f triggeredge
      We used:
      ./cs_mipi_i2c.sh -w -f tgdebncr -p1 1 -p2 [value]
      ./cs_mipi_i2c.sh -r -f tgdebncr
      We could not yet verify in hardware if this works but the readout seemed to work.
      • E
        ess @veye_xumm last edited by
        Hello @veye_xumm,
        I hope you are well and the COVID-19 outbreak takes a mild course. And you stay save and healthy.
        I wanted to tell you that I made a fix work with the Kernel from Allied Vision. It is just hacked together when you update your kernel we will back to switch your kernel.
        Greetings ees.
          veye_xumm @ess last edited by
          @ess
          Hi, thank you, it is indeed typo.
          jetson supports trigger mode, which I have done research on and it has worked. The plan is to organize it and release it along with our new machine vision product line. Estimated 15 days or so.
          E 1 Reply Last reply Reply Quote 1
          • E
            Thank you @veye_xumm,
            that are grade news!
            Is there a chance that you could send us the a beta version?
            Thank you.
            ess
              @ess
              Our company discussed and decided to bring this forward. It is expected that the version will be available to you within 10 days.
              • E
                Thank you so much @veye_xumm!
                That would be a great help for us! We are kind of stuck.
                Do we need to update the kernel then?
                We actually have quite a view dozen of your cameras, and are really happy with them.
                  @ess Thank you for your trust.
                  Sorry to inform you that we have another recent COVID-19 outbreak on our side. There will be a delay in the timing. But I will push this as soon as possible.
                  • E
                    Hello @veye_xumm,
                    Greetings ees.
                      @ess
                      Hi, We have released our version.
                      http://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson#kernel_patch_for_MV_series
                      Please refer to our MV series applications document.
                      http://wiki.veye.cc/index.php/Mv_series_camera_appnotes_4_jetson#Trigger_mode_2
                      I think you can just use this feature.
                      v4l2-ctl --set-ctrl vi_time_out_disable=1
                      • E
                        Hi and thank you sou much!
                        I am Sorry for the late answer. But I am really thankful for your help.
                        Greetings ess
                          @ess You are welcome.
