    SOLVED Direct download img from baidu
    1704
    • V
      Viktor @veye_xumm last edited by Viktor
      @veye_xumm Hi, have tried.
      cat /etc/nv_tegra_release -> r32, 4.4
      Download Image and dtb.
      Copy to /boot
      Edit /boot/extlinux/extlinux.conf -> FDT /boot/dtb file
      And now i have nvidia logo only and loop reboot.
      My system nano b01, imx327.
      Updated: mount sd to host and removed line from extlinux.conf
      Now it is bootable, but camera does not work.
      Also i see initrd.img->initrd.img-4.9.140-tegra in /boot
      Here is kern.log: cam360.tv/etc/kern.log
      Please help.
      • V
        @veye_xumm I also have tried from host:
        copy dtb to kernel/dtb
        sudo ./flash.sh -r -k DTB jetson-nano-qspi-sd mmcblk0p1
        from L4T but nothing, /dev/video0 is not present.
        About system:
        R32 (release), REVISION: 4.4, GCID: 23942405, BOARD: t210ref, EABI: aarch64, DATE: Fri Oct 16 19:44:43 UTC 2020
        number@number:~$ dpkg-query --show nvidia-l4t-core
        nvidia-l4t-core 32.4.4-20201016124427
        Bsp from here:
        https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/Nano/JetPack_4.4.1_Linux_JETSON_NANO_DEVKIT/dts dtb/VEYE-MIPI-327
        Kernel from here:
        https://github.com/veyeimaging/nvidia_jetson_veye_bsp/blob/master/kernel_image/Image_l4t_r32.4.4_veyecam.tar.gz
        So, please tell me how to repair Veye327 system after ubuntu software update?
        • V
          @veye_xumm Here is screenshot, after fresh installation, ubuntu wants 600mb updates, include nvidia l4t4.4: cam360.tv/etc/43-44.jpg
          So i need to update system without reflash as on other native jetson platforms.
          Please help.
            veye_xumm @Viktor last edited by
            @viktor
            If you want to upgrade new version of L4T, I suggest you upgrade the system first, then do our VEYE bsp upgrade.
            This is the list of version we provide:
            Jetpack4.2.2,L4T r32.2.1
            Jetpack4.3,L4T r32.3.1
            Jetpack4.4,L4T r32.4.3
            Jetpack4.4.1,L4T r32.4.4
            Jetpack4.5,L4T r32.5
            Jetpack4.5.1,L4T r32.5.1
            About your failure here:
            @viktor said in Direct download img from baidu:
            Copy to /boot
            Please check the dtb file name and the line you add in /boot/extlinux/extlinux.conf, they must be the same.
            • V
              Have build 4.5.1 from scratch and it works.
              About upgrade.
              Can i apply VEYE image/drivers without reflash and changing /app/home partition?
                @viktor
                http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2#Burning_the_prebuilt_Image_to_upgrade_Jetson_Nano_and_Xavier_NX_Devkit
                • V
                  @veye_xumm Yes. It was first method what i did, but it does not work for Nano. Fdt line brokes system.
                    @viktor
                    pls paste your fdt line here. It must be wrong.
                    • V
                      It was:
                      FDT /boot/tegra210-p3448-0000-p3449-0000-b00.dtb
                      It must works?
                        @viktor
                        I think this line is correct.
                        It's very strange. It works normally in my place.
                        • V
                          @veye_xumm ok. Will try again.
