I2C IR-day/night mode
 i see my confusion now from the wiki that they are bus numbers  however i can not seem to find the i2c bus for the camera, everything should be connected correctly but command i2cdetect -y -r 1is not finding anything even tho it is connect to bus 1
 and i am now also confused on how to use the cmdsudo ./veye5_mipi_i2c.sh -w -f daynightmode -p1 [0,2]
 please tell me how to do this sorry for being noob. sorry for being noob.
 @rob77 said in I2C IR-day/night mode: IMX385 wiki J7 are the Auxiliary IIC
 Please do not use this IIC, the main 15pin FFC cable has an IIC bus already.i2cdetect -y -r 1 Do not use 1 here, use the correct i2c bus number corresponding to your board.
 1.2.3 Nano B01
 i2c num 7 or 8
 1.2.4 Nano A02, Nano 2GB
 i2c bus number is 6.
 @veye_xumm ah i see, i was mistaken thinking it used another I2C conection, cool i unpluged the Aux IIC and did a check, i have a nano B01 and checked the i2cdetect bus 7 and 8 and yep it found it connected, strangely bus 6 is also active even tho nothing is being used on it i think. that solves that. my next problem is useing the day/night comand, im just not sure how to use it as veye_mipi_i2c.sh dosent do anything.
 my goal is while the camera is on that i can switch between IR filter on and off easly.
 @rob77
 http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/#daynightmode./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFF or 0x FE -b 7 or 8
 @veye_xumm thank you for that i tryed ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE -b 7 and 8 to get the ir mode but it still dosent seem to work. i end up getting
 their is probably a step im missing due to still being new to the nano.
 @rob77 no
 @veye_xumm ok.
 running the files just ends with errorno such file or directory. ive tryed running them in terminal and vim with no luck. there is clearly something im missing or not understanding, unlike the raspberry pi you have to enable./enable_i2c_vc.shbut on jetson nano it is already enabled meaning first steps are not required, so i continue with commands that should work but for some reason are not. is there another directory the files are ment to go in? or is there another way to control day/night mode?
 @rob77
 This is a common knowledge of linux.bash: ./veye_mipi_i2c.sh: no such file or directory
 i have the files and tryed this.rob@rob-desktop:~$ ./veye_mipi_i2c.sh bash: ./veye_mipi_i2c.sh: No such file or directory rob@rob-desktop:~$ '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh' /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 1: $'\r': command not found /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 3: $'\r': command not found /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 7: $'\r': command not found /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 8: $'\r': command not found /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 9: $'\r': command not found /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 10: $'\r': command not found /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 11: syntax error near unexpected token `$'\r'' /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: line 11: `print_u'age() rob@rob-desktop:~$i thought maybe it needed a dynamic loader so i did a check. rob@rob-desktop:~$ ldd '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh' not a dynamic executable rob@rob-desktop:~$ file '/home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh' /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/veye_mipi_i2c.sh: ISO-8859 text, with CRLF line terminators
 @rob77
 first
 rob@rob-desktop:~$ cd /home/rob/nvidia_jetson_veye_bsp/i2c_cmd/bin/ rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ ./veye_mipi_i2c.sh ./veye_mipi_i2c.sh: line 1: $'\r': command not found ./veye_mipi_i2c.sh: line 3: $'\r': command not found ./veye_mipi_i2c.sh: line 7: $'\r': command not found ./veye_mipi_i2c.sh: line 8: $'\r': command not found ./veye_mipi_i2c.sh: line 9: $'\r': command not found ./veye_mipi_i2c.sh: line 10: $'\r': command not found ./veye_mipi_i2c.sh: line 11: syntax error near unexpected token `$'\r'' '/veye_mipi_i2c.sh: line 11: `print_usage() rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE -b7 ./veye_mipi_i2c.sh: line 1: $'\r': command not found ./veye_mipi_i2c.sh: line 3: $'\r': command not found ./veye_mipi_i2c.sh: line 7: $'\r': command not found ./veye_mipi_i2c.sh: line 8: $'\r': command not found ./veye_mipi_i2c.sh: line 9: $'\r': command not found ./veye_mipi_i2c.sh: line 10: $'\r': command not found ./veye_mipi_i2c.sh: line 11: syntax error near unexpected token `$'\r'' '/veye_mipi_i2c.sh: line 11: `print_usage()
 @rob77
 Please try this.sudo apt install dos2unix dos2unix ./veye_mipi_i2c.sh
 @veye_xumm thanks that fixd the file into unix and i was able to open it. i then enter the day/night command rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE -b7 should be root!it says should be root? so i redo it as root superuser, but got file/directory error. i tryed other types of commands but getting same error. rob@rob-desktop:~/nvidia_jetson_veye_bsp/i2c_cmd/bin$ sudo -i ./veye_mipi_i2c.sh -w -f daynightmode -p1 0xFE [sudo] password for rob: -bash: ./veye_mipi_i2c.sh: No such file or directory
 JUST fixed it  sudo -s sudo -s want to say thank you for your help and patience with me, a person who has very little experience using linux. the camera is perfect for my project and i will be using it to learn more.
 @rob77 You are welcome.
