    SOLVED bitrate CS-MIPI-IMX307 module
    • P
      pavel_fpga last edited by
      Hi. The datasheet states that CS-MIPI-IMX307 outputs a format of 1920*1080, 1 pixel = RAW-10 or RAW-12 bits. bitrate for full-HD 1080p and 60 fps is 891Mbps/line (CSI-2).
      Your module with this sensor outputs YUV422-8bit. 1 pixel = 16 bit. what output frequency does the pin for mipi_clk have?
        veye_xumm @pavel_fpga last edited by
        @pavel_fpga
        mipi clk :297Mhz
        data speed: 594Mbps/lan
        CS-MIPI-IMX307 support 1080p@30fps
        • P
          pavel_fpga @veye_xumm last edited by pavel_fpga
          @veye_xumm does the frequency change depending on the selected format? 1080p and 30 fps, 720p and 60 fps, or 640x480 and 130 fps
            @pavel_fpga It does not change.
