    SOLVED Please advise compatible mono camera
    General Discussion
    4001
      veye_xumm @desperex last edited by
      @desperex said in Please advise compatible mono camera:
      About two or three years ago, we tried to connect VEYE series products to rk3399, but at that time there were some problems with its BSP.
      Recently we restarted the development plan for rockchip chips.
      The first thing we are doing is to connect VEYE series to firefly's RK3566 board. Now the development has been completed and we have made http://wiki.veye.cc/index.php/ADP-Tfirefly. This board is already online for sale.
      Next, we have to create the adapter board for MV series to ROC-RK3566/8-PC and develop it.
      As for the two boards you mentioned, the rk3399 chip is too old and we have no plans for now.
      Orange Pi 5, we have not studied it before. I will submit it to our R&D department.
      D 1 Reply Last reply Reply Quote 1
      • D
        desperex @veye_xumm last edited by
        @veye_xumm thanks for the input, will give it a try with SC132 on rock pi 4b+, sure there will be lot to do with dts.
        Yes it's old, but still good in terms of cores/RAM/M.2 support, it only lacks extra CSI and 4 lanes/MIPI CSI-2 support.
        It'd be really cool to see your roadmap with all stuff planned and I hope there will be Orange Pi 5 with SC130 adapter for my next project.
          @desperex OK
          • D
            desperex @veye_xumm last edited by desperex
            Just finished setting up RAW-MIPI-SC132M camera on rock pi 4b using rpi mvcam ported driver.
            Now I'm trying to create a working rkisp1 pipeline, which is not straightforward for me, so I've got some questions:
            1. The sensor supports only Y8 and Y10 formats so how do I map it to ISP which supports only YUV/RGB/bayer formats? At the moment I'm getting 'Broken pipe' error. In topology (below) I need to map formats of rkisp1_isp:pad0 and 'mvcam 4-003b:pad0
            2. How to upgrade camera's firmware? Didn't find any sources on your github, only binaries (incompatible).
            EDIT: So this setup is to use the sensor in OpenMV, if rkisp1 just can't work with mono cams, is there any other way to use this cam in my configuration?
            Below is media topology for reference:
            media-ctl -p -d "platform:rkisp1"
            Media controller API version 5.15.90
            Media device information
            driver          rkisp1
            model           rkisp1
            serial
            bus info        platform:rkisp1
            hw revision     0xa
            driver version  5.15.90
            Device topology
            - entity 1: rkisp1_isp (4 pads, 5 links)
            	pad0: Sink
            		[fmt:SRGGB10_1X10/1080x1280 field:none
            		 crop.bounds:(0,0)/1080x1280
            		 crop:(0,0)/1024x768]
            		<- "mvcam 4-003b":0 [ENABLED]
            	pad1: Sink
            		[fmt:unknown/0x0 field:none]
            		<- "rkisp1_params":0 [ENABLED,IMMUTABLE]
            	pad2: Source
            		[fmt:YUYV8_2X8/1024x768 field:none
            		 crop.bounds:(0,0)/1024x768
            		-> "rkisp1_resizer_mainpath":0 [ENABLED]
            		-> "rkisp1_resizer_selfpath":0 []
            	pad3: Source
            		-> "rkisp1_stats":0 [ENABLED,IMMUTABLE]
            - entity 6: rkisp1_resizer_mainpath (2 pads, 2 links)
            	pad0: Sink
            		[fmt:YUYV8_2X8/1024x768 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range
            		 crop:(0,0)/800x600]
            		<- "rkisp1_isp":2 [ENABLED]
            	pad1: Source
            		[fmt:YUYV8_2X8/1024x768 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
            		-> "rkisp1_mainpath":0 [ENABLED,IMMUTABLE]
            - entity 9: rkisp1_resizer_selfpath (2 pads, 2 links)
            	pad0: Sink
            		[fmt:YUYV8_2X8/800x600 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range
            		 crop.bounds:(0,0)/800x600
            		 crop:(0,0)/800x600]
            		<- "rkisp1_isp":2 []
            	pad1: Source
            		[fmt:YUYV8_2X8/800x600 field:none colorspace:srgb xfer:srgb ycbcr:601 quantization:lim-range]
            		-> "rkisp1_selfpath":0 [ENABLED,IMMUTABLE]
            - entity 12: rkisp1_mainpath (1 pad, 1 link)
                         type Node subtype V4L flags 0
                         device node name /dev/video5
            	pad0: Sink
            		<- "rkisp1_resizer_mainpath":1 [ENABLED,IMMUTABLE]
            - entity 16: rkisp1_selfpath (1 pad, 1 link)
                         device node name /dev/video6
            	pad0: Sink
            		<- "rkisp1_resizer_selfpath":1 [ENABLED,IMMUTABLE]
            - entity 20: rkisp1_stats (1 pad, 1 link)
                         device node name /dev/video7
            	pad0: Sink
            		<- "rkisp1_isp":3 [ENABLED,IMMUTABLE]
            - entity 24: rkisp1_params (1 pad, 1 link)
                         device node name /dev/video8
            	pad0: Source
            		-> "rkisp1_isp":1 [ENABLED,IMMUTABLE]
            - entity 28: mvcam 4-003b (1 pad, 1 link)
                         device node name /dev/v4l-subdev3
            	pad0: Source
            		[fmt:Y8_1X8/1080x1280 field:none colorspace:srgb
            		 crop:(0,0)/1080x1280]
            		-> "rkisp1_isp":0 [ENABLED]
              @desperex
              Can't do that, after all, this is a mono sensor.
              mv seriescamera access to rockchip platform is what we are promoting. It is estimated that it will be completed within a month.
              As for the upgrade tool, we will also provide the corresponding binary file.
              • D
                @veye_xumm After deep analysis of rkisp driver I see two completely different implementations:
                1. from vendor: https://github.com/JeffyCN/mirrors/commit/72e4ba0ccf477a6d90f40a2fb5e3bc9e5025093b. That one explicitly supports MEDIA_BUS_FMT_Y8_1X8 and MEDIA_BUS_FMT_Y10_1X10 as input for ISP. I tried to bring all the changes to mainline (5.15.90) but it still fails somewhere when setting pipeline
                2. from collabora, mainline kernel, it seems to also have some mono camera support https://github.com/torvalds/linux/commit/9a0e3cd50d3967b669f0f0ea79a7054c7877d95b. But they require the camera to be set to YUV422 which can't be done with RAW-MIPI-SC132M
                @veye_xumm said in Please advise compatible mono camera:
                EDIT: There's also a warning "mvcam 4-003b: Consider updating driver mvcam to match on endpoints", not sure if it's harmful or not
                https://github.com/torvalds/linux/blob/v6.1/drivers/media/v4l2-core/v4l2-async.c#L142
                Ok will work on no.1 while waiting for any updates from you
                Thanks!
                  @desperex
                  This will not cause problems.
                  For machine vision type cameras, many times the isp function is not needed. Many steps in isp are dealing with color, and this is certainly not necessary to do. There are also valid operations such as AE, gamma, etc. But there are many customer application scenarios that do not need these functions.
                  Which functions of isp do you need, please?
                  • D
                    Just AE,IS and crop, if there was a way to skip ISP, I'd do.
                    Other reqs would come up later, now I just can't start developing CV part.
                    • D
                      desperex last edited by desperex
                      @veye_xumm, is there a particular reason why veye-raw drivers are missing these controls:
                      • V4L2_CID_ANALOGUE_GAIN_
                      • V4L2_CID_EXPOSURE_
                      • V4L2_CID_HBLANK_
                      • V4L2_CID_VBLANK_
                      EDIT: Figured out how to implement ANALOGUE_GAIN but the rest requires your help... EXPOSURE should be somehow converted from microseconds to image lines, the rest is just not in specs.
                      Why PIXEL_RATE in driver is set to constant 750000000?
                      Shouldn't it be like that?
                      #define MVCAM_LINK_FREQ 750000000
                      #define MVCAM_NUM_DATA_LANES 2
                      #define MVCAM_PIXEL_RATE_8BIT = (MVCAM_LINK_FREQ * 2 * MVCAM_NUM_DATA_LANES / 8)
                      #define MVCAM_PIXEL_RATE_10BIT = (MVCAM_LINK_FREQ * 2 *  MVCAM_NUM_DATA_LANES / 10)
                      Since RAW-MIPI-SC132M camera has no AE, I'm evaluating libcamera for this purpose. And it has some requirements:
                      https://git.linuxtv.org/libcamera.git/tree/Documentation/sensor_driver_requirements.rst#n25
                      Is there any document that shows how to deal with your raw camera sensor, like creating control loop etc.?
                      What's your best practices of using this sensor in opencv+libcamera scenarios?
                      And BTW I know it's too early but maybe there's already some progress=)
                      I'm just interested how do you see that task, is it also something to support stats & params of Rockchip ISPs?
                      veye_xumm D 2 Replies Last reply Reply Quote 0
                      • D
                        Another issue that I'm having with gstreamer that I run like this:
                        gst-launch-1.0 v4l2src device=/dev/video1 ! "video/x-raw, width=1024, height=768" ! queue ! autovideosink -e
                        is sometimes gives me 'squeezed frames moving up' effect (please see video). So that may happen right after the launch of gstreamer and I have to relaunch it. I haven't had that issue with the same setup but different camera (imx219), but my ISP driver is a little bit patched to support Y8 and Y10...
                        Do you know is it camera related or ISP related or maybe some gstreamer bug?
                          @desperex
                          The RAW-MIPI-SC132M itself comes with an MCU controller, so it is not a sensor. So the registers provided by this camera are much easier to understand. The exposure time, for example, uses microseconds instead of lines. hblank and vblank do not need customers to worry at all.
                          MV-MIPI-SC130M has a AE built inside.
                          • D
                            desperex @desperex last edited by
                            Is there any news?
                              @desperex
                              We apologize for the delay in getting back to you. We have now completed the driver development for the MV series and RAW series on the RK3588. Please refer to the link below for details.
                              http://wiki.veye.cc/index.php/MV_Camera_on_Firfly_Boards
                              Please note that we did not use the internal ISP function of the RK3588, nor did we debug libcamera. This is because our MV series cameras have AE function. If you are using the RAW series module, please use manual exposure mode.
                              • D
                                @veye_xumm Thanks!
