    I2c tools failed
    2796
    • V
      Viktor @Viktor last edited by Viktor
      Have added -d -b:
      sudo ./veye_mipi_i2c.sh -r -f devid -b 6 -d 0x3b
      ====I2C write:<0x3b> <0x7> <0xfe>====
      device id is 0xc8
      Failed to write register index 0
      sudo ./veye_mipi_i2c.sh -r -f hdver -b 6 -d 0x3b
      hardware version is 0xc8
      Direct bin run:
      out=$(./i2c_read 6 0x3b 0x01)
      echo $out
      Using i2C device /dev/i2c-6 ====I2C read:<0x3b> <0x1> <0x1>==== Read i2c addr 3B
      Tell me please, what is default AE/framerate state?
      • V
        Tried bus 7:
        sudo ./veye_mipi_i2c.sh -r -f devid -b 7
        device id is 0x 6
        sudo ./veye_mipi_i2c.sh -r -f hvdev -b 7
        sudo ./veye_mipi_i2c.sh -r -f hdver -b 7
        hardware version is 0x 3
        It works now.
        • V
          I wrote mshutter to 0x41 for constant 25 fps, am i right?
          Cause in low light i have high exposure.
          night
            veye_xumm @Viktor last edited by veye_xumm
            @viktor
            This camera is fixed frame rate. You do not need to change the exposure time for that.
            I suggest you use default parameters first, and change if necessary.
            Please use videofmt for 25fps. It is 30fps by default.
            http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/zh#videoformat
            • V
              Viktor @veye_xumm last edited by
              @veye_xumm Ok, I tryed wdmode, Pal and mshutter. And now it is good night picture.
              • V
                Hi Meng,
                Can you explain what parameter makes that effect with multiple shadows on image?
                alt text
                  @viktor
                  Please try close wdr.
                  http://wiki.veye.cc/index.php/VEYE-MIPI-290/327_i2c/zh#wdrmode
                  Because WDR uses two frames of data at different time points to be merged into one frame.
                  If the exposure time is long and the vehicle is fast, there will be problems in your image.You can also try to reduce ghosting by reducing the exposure time without turning off WDR.
                  • V
                    Viktor @veye_xumm last edited by Viktor
                    Ok, and which parameter controls exposure in i2c?
                    Like on CS?
                    ./cs_mipi_i2c.sh -w -f aetime -p1 XXX
                    range:(100,1/framerate]
                      @viktor
                      The parameters of the veye series are not as flexible as those of the cs series, and the parameter you want is mshutter.
                      • V
                        Ok. Have tried mshutter, but shadows presents in all cases.
                        If i write mshutter 0x46( 1/1000 ) i expect very short exposure and more dark image. It is ok because we are using light at night.
                        But at daylight frame is over exposured. So works only 0x40 (auto shutter). Then at night we have this effect: http://forum.veye.cc/post/185
                        Here is only mshutter auto:
                        alt text
                          @viktor said in I2c tools failed:
                          Pls try close wdr as I suggested before.
                          • V
                            Wdr already closed.
                            May be i should restart system?
                            Pal i set before run programm.
                            But other controls can i set before too?
                              @viktor
                              1. pls post your cmd to close wdr.
                              2. pls try close 3d denoise.
                              V 2 Replies Last reply Reply Quote 0
                              • V
                                • V
                                  Here is cmd:
                                  sudo ./veye_mipi_i2c.sh -w -f videoformat -p1 PAL
                                  sudo ./veye_mipi_i2c.sh -w -f wdrmode -b 7 -p1 0x00
                                  sudo ./veye_mipi_i2c.sh -w -f mshutter -b 7 -p1 0x40
                                  alt text
                                  So it is a daylight. Sensor has auto shutter mode, cars speed is slow because it is parking barrier.
                                  Why is double image?
                                    please add this one :
                                    ./veye_mipi_i2c.sh -w -f denoise -p1 x00 -b7
                                    • V
                                      Thanks. Looks like fixed.
                                      alt text
                                        @viktor
                                        OK. So 3D denoise is the key. You can try to have a low level 2d denoise.
                                        • V
                                          Thank you Meng.
                                            @viktor
                                            You are welcome.
