    SOLVED 在向自己的Image中添加驱动的过程中遇到了error during i2c read probe (-121)
    FPD LINK III Camera
    2162
      veye_xumm @robot last edited by
      @robot
      @robot said in 在向自己的Image中添加驱动的过程中遇到了error during i2c read probe (-121):
      现在的问题是我改后的dtb可以完美的搭配预编译的Image使用,那么我是不是可以就此确认我的dtb和我的硬件已经没有问题了?
      应该是的。你怀疑你自己编译的Image不行吗?
      另一方面,从dmesg来看ds90ub954的驱动正常运行,我也已经从i2c-7读出了0x30 0x19 0x3b三个地址,那么是不是有可能我需要对cssc132的驱动做出一定的修改才能正常使用?如果是我需要改什么?
      已经有了0x3b,说明整个fpdlink的初始化通路都成功了,而且跟摄像头的i2c已经通了。
      这种情况,按理说应该正常识别到摄像头了啊。你确认实际摄像头型号跟dtb中的型号一致吗?
      • R
        robot @veye_xumm last edited by
        @veye_xumm said in 在向自己的Image中添加驱动的过程中遇到了error during i2c read probe (-121):
        mr123@mr123-emmc3:~$
        mr123@mr123-emmc3:~$ dmesg |grep cssc
        [ 7.762902] cssc132 7-003b: probing v4l2 sensor
        [ 7.763294] cssc132 7-003b: tegracam sensor driver:cssc132_v2.0.6
        [ 7.764842] cssc132 7-003b: read sensor id 0132
        [ 7.769477] cssc132 7-003b: camera id is cs-mipi-sc132
        [ 7.774748] cssc132 7-003b: Detected CS_MIPI_SC132 camera
        [ 7.774797] cssc132 8-003b: probing v4l2 sensor
        [ 7.775142] cssc132 8-003b: tegracam sensor driver:cssc132_v2.0.6
        [ 7.775348] cssc132 8-003b: cs_sc132_board_setup: error during i2c read probe (-121)
        [ 7.783103] cssc132 8-003b: board setup failed
        [ 7.787616] cssc132: probe of 8-003b failed with error -121
        [ 7.940285] vi 54080000.vi: subdev cssc132 7-003b bound
        是的,这个是我使用预编译的Image的dmesg,dtb都是同一个
          @robot
          这个dmesg看,已经成功了,一切正常。
          • R
            是的,但是这个Image是从github上下载的,我自己的一直都不行:
            [ 1.711145] cssc132 7-003b: probing v4l2 sensor
            [ 1.711521] cssc132 7-003b: tegracam sensor driver:cssc132_v2.0.6
            [ 1.712203] cssc132 7-003b: cs_sc132_board_setup: error during i2c read probe (-121)
            [ 1.712206] cssc132 7-003b: board setup failed
            [ 1.712267] cssc132: probe of 7-003b failed with error -121
            [ 1.712310] cssc132 8-003b: probing v4l2 sensor
            [ 1.712663] cssc132 8-003b: tegracam sensor driver:cssc132_v2.0.6
            [ 1.712861] cssc132 8-003b: cs_sc132_board_setup: error during i2c read probe (-121)
            [ 1.712864] cssc132 8-003b: board setup failed
            [ 1.712914] cssc132: probe of 8-003b failed with error -121
            mr123@mr123-emmc3:~$ i2cdetect -y -r 7
            0 1 2 3 4 5 6 7 8 9 a b c d e f
            00: -- -- -- -- -- -- -- -- -- -- -- -- --
            10: -- -- -- -- -- -- -- -- -- 19 -- -- -- -- -- --
            30: UU -- -- -- -- -- -- -- -- -- -- 3b -- -- -- --
            40: UU -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
            70: -- -- -- -- -- -- -- --
            所以就现在来说我比较怀疑cssc132驱动的问题。
            或者说还有其他原因会导致这个现象吗?
            在此过程中我只改变的Image。
              @robot
              看一下你的dmes全部内容,954这颗芯片的初始化,难不成跑到了132模组初始化后面去了?
              或者你吧整个dmesg的输出保存成文件,post上来我看看。
              • R
                您好,
                是这样的,确实是先初始化的cssc132然后再初始化的ds90ub954:
                [ 1.910350] i2c /dev entries driver
                [ 1.912132] i2c i2c-6: Added multiplexed i2c bus 7
                [ 1.912675] i2c i2c-6: Added multiplexed i2c bus 8
                [ 1.912681] i2c-mux-gpio cam_i2cmux: 2 port mux on Tegra I2C adapter adapter
                [ 1.913916] cssc132 7-003b: probing v4l2 sensor
                [ 1.914301] cssc132 7-003b: tegracam sensor driver:cssc132_v2.0.6
                [ 1.914460] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
                [ 1.914533] cssc132 7-003b: cs_sc132_board_setup: error during i2c read probe (-121)
                [ 1.922319] cssc132 7-003b: board setup failed
                [ 1.926835] cssc132: probe of 7-003b failed with error -121
                [ 1.926881] cssc132 8-003b: probing v4l2 sensor
                [ 1.927229] cssc132 8-003b: tegracam sensor driver:cssc132_v2.0.6
                [ 1.927366] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x3b
                [ 1.927439] cssc132 8-003b: cs_sc132_board_setup: error during i2c read probe (-121)
                [ 1.935199] cssc132 8-003b: board setup failed
                [ 1.939703] cssc132: probe of 8-003b failed with error -121
                [ 1.939793] i2c-ds90ub954 7-0030: ds90ub954_probe: start
                [ 1.939798] i2c-ds90ub954 7-0030: ds90ub954_parse_dt: deserializer:
                [ 1.939804] i2c-ds90ub954 7-0030: pass-gpio not found, ignoring
                [ 1.939808] i2c-ds90ub954 7-0030: lock-gpio not found, ignoring
                [ 1.939813] i2c-ds90ub954 7-0030: pdb-gpio not found, ignoring
                [ 1.939818] i2c-ds90ub954 7-0030: ds90ub954_parse_dt: - csi-lane-count 2
                [ 1.939824] i2c-ds90ub954 7-0030: ds90ub954_parse_dt: - csi-lane-speed 800
                [ 1.939828] i2c-ds90ub954 7-0030: ds90ub954_parse_dt: - test-pattern disabled
                [ 1.939833] i2c-ds90ub954 7-0030: ds90ub954_parse_dt: - discontinuous clock used
                [ 1.939860] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: parsing serializers device tree:
                [ 1.939867] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - serializer rx-channel: 0
                [ 1.939872] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: -test-pattern disabled
                [ 1.939877] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - csi-lane-count 2
                [ 1.939882] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio0-output-enable property not found
                [ 1.939886] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio0-output-enable to default val: 0
                [ 1.939891] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio1-output-enable property not found
                [ 1.939895] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio1-output-enable to default val: 0
                [ 1.939900] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio2-output-enable property not found
                [ 1.939904] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio2-output-enable to default val: 0
                [ 1.939908] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio3-output-enable property not found
                [ 1.939912] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio3-output-enable to default val: 0
                [ 1.939916] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio0-control property not found
                [ 1.939920] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio0-control to default val: 0b1000
                [ 1.939924] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio1-control property not found
                [ 1.939928] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio1-control to default val: 0b1000
                [ 1.939932] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio2-control property not found
                [ 1.939936] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio2-control to default val: 0b1000
                [ 1.939940] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - gpio3-control property not found
                [ 1.939943] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: gpio3-control to default val: 0b1000
                [ 1.939947] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - hs-clk-div property not found
                [ 1.939951] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - hs-clk-div set to default val: 0x2 (div by 4)
                [ 1.939955] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - div-m-val property not found
                [ 1.939959] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - div-m-val set to default val: 1
                [ 1.939963] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - div-n-val property not found
                [ 1.939967] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - div-n-val set to default val: 0x28
                [ 1.939972] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - i2c-address: 0x19
                [ 1.940064] i2c-ds90ub954 7-0030: ds90ub953_i2c_client init client done
                [ 1.940096] i2c-ds90ub954 7-0030: ds90ub953_regmap_init init regmap done
                [ 1.940216] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - num of slave alias pairs: 1
                [ 1.940221] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - slave addr: 0x3B, alias addr: 0x3B
                [ 1.940225] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - discontinuous clock used
                [ 1.940230] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - i2c-pass-through-all disabled
                [ 1.940234] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - virtual-channel-map property not found
                [ 1.940238] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: - virtual-channel-map set to default val: 0xE4
                [ 1.940242] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: serializer 0 successfully parsed
                [ 1.940247] i2c-ds90ub954 7-0030: ds90ub953_parse_dt: done
                [ 1.954771] i2c-ds90ub954 7-0030: ds90ub954_init starting
                [ 1.956670] i2c-ds90ub954 7-0030: ds90ub954_init: device ID: 0x60, code:_UB954, revision: 0x20
                  您好,
                  你看一下你合并我们的代码部分,注意makefile和kconfig中954和132两个驱动的先后顺序。 这个影响调用顺序。
                  • R
                    好的,谢谢您了。
                    另外我今天新到四个cssc132相机,如果想要全部识别到的话,我是否需要对其进行硬件上的修改?
                      @robot
                      不客气。 我不太清楚你买的订单的硬件信息。 可以看我们这页文章:
                      • R
                        好的,谢谢您,Image的问题解决了。
                        关于四路相机的问题,我希望在新帖中向您提问。
                          @robot ok
