    UNSOLVED IMX307使用抓拍模式pipeline启动失败
    1605
      lyj last edited by
      IMX307,使用以下参数 v4l2src num-buffers=1 /dev/video0! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvjpegenc ! filesink location=1.jpg 启动pipeline,提示cannot find appsink in maanual pipeline,开启失败
        veye_xumm @lyj last edited by
        @lyj
        请直接执行:
        gst-launch-1.0 v4l2src num-buffers=1 ! "video/x-raw,format=(string)UYVY, width=(int)2560, height=(int)1440" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvjpegenc ! filesink location=jpgname.jpg
        把你这边的提示信息发出来看看。
          lyj @veye_xumm last edited by
          @veye_xumm 可我是双相机呢,我有两个相机,我要指定一下吧
            @lyj
            取video0
            gst-launch-1.0 v4l2src -d /dev/video0 num-buffers=1 ! "video/x-raw,format=(string)UYVY, width=(int)2560, height=(int)1440" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvjpegenc ! filesink location=jpgname.jpg
            取video1
            gst-launch-1.0 v4l2src -d /dev/video1 num-buffers=1 ! "video/x-raw,format=(string)UYVY, width=(int)2560, height=(int)1440" ! nvvidconv ! "video/x-raw(memory:NVMM),format=(string)I420" ! nvjpegenc ! filesink location=jpgname.jpg
              @veye_xumm 我试试
                cap = cv2.VideoCapture('v4l2src -d /dev/video0 num-buffers=1 ! \"video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080\" ! nvvidconv ! \"video/x-raw(memory:NVMM),format=(string)I420\" ! nvjpegenc ! filesink location=jpgname.jpg')
                  @lyj
                  这脚本不是直接这样扔到python代码里面的啊。
                  你如果一定要用python去调用shell脚本。可以参考:
                  import subprocess
                  # 定义要执行的GStreamer命令
                  gstreamer_command = "gst-launch-1.0 v4l2src -d /dev/video0 num-buffers=1 ! 'video/x-raw,format=(string)UYVY, width=(int)2560, height=(int)1440' ! nvvidconv ! 'video/x-raw(memory:NVMM),format=(string)I420' ! nvjpegenc ! filesink location=jpgname.jpg"
                  # 使用subprocess运行GStreamer命令
                  try:
                      subprocess.run(gstreamer_command, shell=True, check=True)
                      print("GStreamer command executed successfully.")
                  except subprocess.CalledProcessError as e:
                      print(f"Error executing GStreamer command: {e}")
                  L 3 Replies Last reply Reply Quote 0
                    @veye_xumm 为啥视频预览可以用python调用,这个不行呢
                      @veye_xumm 还得是大佬出手,我还有个问题,这个图片只能保存成jpg吗?能不能是bmp格式
                        @veye_xumm 请问这个抓拍的图片可以弄成视频流吗?必须保存成图片吗?
                          @lyj 这个本质上是gstreamer的一个命令行,你可以上网上或者上英伟达的资料网站上查一下是否有压缩成视频流的,或者压缩成bmp的相关gstreamer plugin。
