    UNSOLVED ROC-RK3588S-PC and IMX462
    Rockchip App camera
    5242
    • N
      natzguk last edited by
      Hi
      I have ROC-RK3588S-PC and IMX462. I followed the instructions and installed the image.
      ROC-RK3588S-PC_Ubuntu_v1.0.6f_veye_mvcam_vbyone_230830.img
      Unfortunately dmesg | grep veye shows an error. See screenshots.
      Please help.
      https://imgbly.com/ib/PIGIshhUce.jpg
      https://imgbly.com/ib/J06XI5XFSE.jpg
        veye_xumm @natzguk last edited by
        @natzguk
        @natzguk said in ROC-RK3588S-PC and IMX462:
        Do not use this image.
        Use this one:
        ROC-RK3588S-PC_Ubuntu_v1.0.4b_221226_veyecam2m.img
        • N
          natzguk @veye_xumm last edited by
          It works now! Thank you.
          Maybe you can update the documentation. https://wiki.veye.cc/index.php/VEYE_CS_Camera_on_Firfly_Boards
          For me it was not clear and I just downloaded the latest image for RK3588S which is v1.0.6f
          • N
            natzguk @veye_xumm last edited by natzguk
            Hi @veye_xumm
            On RK3588S with opencv I only get slow FPS reading from IMX462 of around 15 FPS. The same code on RaspberryPi can read with 30FPS.
            Here is what I tried:
            1.)
            camera.open(
                    "v4l2src device=/dev/video0 ! video/x-raw, format=(string)NV16, width=(int)1920, height=(int)1080,framerate=30/1 ! videoconvert ! appsink'",
                    cv::CAP_GSTREAMER);
            Only 11-13 FPS
            2.)
            camera.open(
                    "v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=(string)UYVY, width=(int)1920, height=(int)1080 ! appsink",
                    cv::CAP_GSTREAMER);
            Can open camera but can not read frame
            3.)
            camera.open(0, cv::CAP_V4L2);
            camera.set(cv::CAP_PROP_FRAME_WIDTH, 1920);
            camera.set(cv::CAP_PROP_FRAME_HEIGHT, 1080);
            Here is the output of dmesg
            firefly@firefly:~$ dmesg | grep veye
            [    6.065238] veyecam2m 7-003b: veye camera driver version: 00.01.01
            [    6.065262] veyecam2m 7-003b: Failed to get power-gpios, maybe no use
            [    6.065422] veyecam2m 7-003b: supply avdd not found, using dummy regulator
            [    6.065498] veyecam2m 7-003b: supply dovdd not found, using dummy regulator
            [    6.065531] veyecam2m 7-003b: supply dvdd not found, using dummy regulator
            [    6.065560] veyecam2m 7-003b: could not get default pinstate
            [    6.065565] veyecam2m 7-003b: could not get sleep pinstate
            [    6.065580] veyecam2m 7-003b: Success to get veyecam2m endpoint data lanes, dts uses 2 lanes
            [    6.187925] veyecam2m 7-003b:  camera id is veyecam2m
            [    6.190818] veyecam2m 7-003b: sensor is IMX462
            [    6.190860] veyecam2m 7-003b: board type is ONE board
            [    6.191449] rockchip-csi2-dphy csi2-dphy0: dphy0 matches m00_b_veyecam2m 7-003b:bus type 5
            And v4l2-ctl
            firefly@firefly:~$ v4l2-ctl --list-formats-ext
            ioctl: VIDIOC_ENUM_FMT
                    Type: Video Capture Multiplanar
                    [0]: 'NV16' (Y/CbCr 4:2:2)
                            Size: Stepwise 64x64 - 1920x1080 with step 8/8
                    [1]: 'NV61' (Y/CrCb 4:2:2)
                    [2]: 'NV12' (Y/CbCr 4:2:0)
                    [3]: 'NV21' (Y/CrCb 4:2:0)
                    [4]: 'YUYV' (YUYV 4:2:2)
                    [5]: 'YVYU' (YVYU 4:2:2)
                    [6]: 'UYVY' (UYVY 4:2:2)
                    [7]: 'VYUY' (VYUY 4:2:2)
                    [8]: 'RGB3' (24-bit RGB 8-8-8)
                    [9]: 'RGBP' (16-bit RGB 5-6-5)
                    [10]: 'BGRH' (18-bit BGRX 6-6-6-14)
                    [11]: 'RGGB' (8-bit Bayer RGRG/GBGB)
                    [12]: 'GRBG' (8-bit Bayer GRGR/BGBG)
                    [13]: 'GBRG' (8-bit Bayer GBGB/RGRG)
                    [14]: 'BA81' (8-bit Bayer BGBG/GRGR)
                    [15]: 'RG10' (10-bit Bayer RGRG/GBGB)
                    [16]: 'BA10' (10-bit Bayer GRGR/BGBG)
                    [17]: 'GB10' (10-bit Bayer GBGB/RGRG)
                    [18]: 'BG10' (10-bit Bayer BGBG/GRGR)
                    [19]: 'RG12' (12-bit Bayer RGRG/GBGB)
                    [20]: 'BA12' (12-bit Bayer GRGR/BGBG)
                    [21]: 'GB12' (12-bit Bayer GBGB/RGRG)
                    [22]: 'BG12' (12-bit Bayer BGBG/GRGR)
                    [23]: 'BYR2' (16-bit Bayer BGBG/GRGR)
                    [24]: 'GB16' (16-bit Bayer GBGB/RGRG)
                    [25]: 'GR16' (16-bit Bayer GRGR/BGBG)
                    [26]: 'RG16' (16-bit Bayer RGRG/GBGB)
                    [27]: 'Y16 ' (16-bit Greyscale)
                    [28]: 'GREY' (8-bit Greyscale)
                    [29]: 'EBD8' (Embedded data 8-bit)
                    [30]: 'SPD6' (Shield pix data 16-bit)
                    [31]: 'Y12 ' (12-bit Greyscale)
                    [32]: 'Y10 ' (10-bit Greyscale)
            Please help
              @natzguk
              Have you tried these samples here?
              https://github.com/veyeimaging/rk35xx_firefly/tree/main/linux/samples/opencv/veye camera
              • N
                Yes please see my examples.
                camera.open(
                        cv::CAP_GSTREAMER);
                Does not work. I can open the camera but the frames are always empty.
                firefly@firefly:~$ GST_DEBUG=3 gst-launch-1.0 v4l2src io-mode=dmabuf device=/dev/video0 ! video/x-raw, format=UYVY, width=1920, height=1080 ! appsink                 Setting pipeline to PAUSED ...
                Pipeline is PREROLLED ...
                0:00:00.517057017 46983   0x5597da8c60 WARN                    v4l2 gstv4l2object.c:4735:gst_v4l2_object_probe_caps:<v4l2src0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument
                New clock: GstSystemClock
                0:00:00.517846562 46983   0x5597da8c60 WARN                    v4l2 gstv4l2object.c:4528:gst_v4l2_object_get_crop_rect:<v4l2src0:src> Failed to get default crop rectangle with VIDIOC_G_SELECTION: Invalid argument
                0:00:00.517940188 46983   0x5597da8c60 WARN                    v4l2 gstv4l2object.c:3278:gst_v4l2_object_reset_compose_region:<v4l2src0:src> Failed to get default compose rectangle with VIDIOC_G_SELECTION: Invalid argument
                0:00:00.522044833 46983   0x5597da8c60 WARN          v4l2bufferpool gstv4l2bufferpool.c:850:gst_v4l2_buffer_pool_start:<v4l2src0:pool0:src> Uncertain or not enough buffers, enabling copy threshold
                • N
                  natzguk @natzguk last edited by
                  I did some more tests and tested all the examples from https://github.com/veyeimaging/rk35xx_firefly/tree/main/linux/samples/opencv/veye camera
                  Files 1-3 do not work. No frames are shown. Only v4l2_opencv_show4.py works but it only reads with 15 FPS.
                  Can you confirm that the python opencv examples 1-3 work with ROC-RK3588S-PC and IMX462 ?
                  • N
                    Hi @veye_xumm
                    Do you know why UYVY does not work from the examples?
                    • N
                      @veye_xumm Please help.
                      v4l2_opencv_show1.py
                      v4l2_opencv_show2.py
                      v4l2_opencv_show3.py
                      Do not work with ROC-RK3588S-PC and IMX462.
                        @natzguk
                        I'm sorry for not replying earlier.
                        To be honest, we are not very familiar with OpenCV. I believe the low frame rate is due to the software-based UYVY to preview data format conversion, which involves CPU processing for each pixel, leading to inefficiency.
                        I will verify the samples and your script as soon as possible.
                        • N
                          Only format=NV12 (v4l2_opencv_show4.py) works with OpenCV but it requires videoconvert which is very slow.
                          I want to use format=UYVY (v4l2_opencv_show2.py) but it does not work with
                          ROC-RK3588S-PC and IMX462. I believe it is a problem with the driver for ROC-RK3588S-PC. The same code with format=UYVY works with Raspberry PI 4.
                          • N
                            Did you have any chance to check the samples
                            with ROC-RK3588S-PC and IMX462?
                            • N
                              @veye_xumm please help
                                @natzguk
                                I apologize for the delay in responding to your question. In fact, as mentioned here, the VICAP module of RK3588 does not support outputting the UYVY format, so please use the NV12 format instead.
                                Actually, I think using the NV12 format is a good choice.It will not lead to a decrease in system efficiency.
                                Indeed, as you said, only sample4 works correctly. These samples are just collected examples of common ways to use OpenCV to access the camera, provided for customers as a reference.
                                As mentioned before, our expertise in OpenCV development is not extensive.
                                videoconvert is indeed an issue. I believe the internal data format of OpenCV is RGBA, and regardless of whether you use UYVY or NV12, conversion is needed.
                                • N
                                  If I use NV12 as described in sample4 I can only read frames with max 15FPS from the camera. This will not work for our application.
                                  Can you show me an example which can read frames with 30FPS?
                                    @natzguk I believe the key issue lies in videoconvert and the display, which has low efficiency. You can refer to our GStreamer for previewing.
                                    • N
                                      I am not talking about previewing the frame. I am talking about simply reading the frame. No processing.
                                      Here is the example with sample4:
                                      import numpy as np
                                      import cv2 as cv
                                      import os
                                      import time
                                      cap = cv.VideoCapture('v4l2src device=/dev/video0 ! video/x-raw, format=NV12, width=1920, height=1080, framerate=30/1 ! videoconvert ! appsink', cv.CAP_GSTREAMER)
                                      if not cap.isOpened():
                                          print("Cannot capture from camera. Exiting.")
                                          os._exit(0)
                                      last_time = time.time()
                                      frame_count = 0
                                      while True:
                                          ret, frame = cap.read()
                                          if not ret:
                                              break
                                          frame_count += 1
                                          this_time = time.time()
                                          if this_time - last_time >= 1.0:
                                              fps = frame_count / (this_time - last_time)
                                              print(f"FPS: {fps}")
                                              last_time = this_time
                                              frame_count = 0
                                      cap.release()
                                      cv.destroyAllWindows()
                                      Simply reading the frame is currently only getting 15 FPS on ROC-RK3588S-PC. I believe this is a driver issue with NV12.
                                        @natzguk pls try this:
                                        https://github.com/veyeimaging/rk35xx_firefly/blob/main/linux/samples/gstreamer/veye camera/preview.sh
