    SOLVED VEYE-imx462 and Orin Nano developer kit problem
    2291
      veye_xumm @joe last edited by
      @joe
      Sorry, the information is not complete.
      • J
        joe @veye_xumm last edited by
        Thank you for your online response.
        What about my second question. Have I do something wrong that the values of parameters do not set?
        ./veye_mipi_i2c.sh -b 9 -r -f mshutter
        r mshutter is 0x 1
        ./veye_mipi_i2c.sh -b 9 -w -f mshutter -p1 0x44
        w mshutter is 0x44
        r mshutter is 0x 1
        It have the fix value every time i get it!
        Thank you for your ongoing support
          @joe
          To confirm your I2C bus, please enter the following two commands and send the results back to me.
          ./veye_mipi_i2c.sh -r -f hdver -b 9
          ./veye_mipi_i2c.sh -r -f hdver -b 10
          • J
            The results:
            hardware version is 0x 1
            release date is 20 1- 1- 1
            hardware version is 0x 7
            release date is 20 0- 0- 0
              @joe
              @joe said in VEYE-imx462 and Orin Nano developer kit problem:
              So your camera is connecting to i2c bus 10.
              Please use -b 10 as parameter for ./veye_mipi_i2c.sh
              • J
                It seems that the parameters I've configured are retaining their previous values:
                ./veye_mipi_i2c.sh -b 10 -r -f mshutter
                r mshutter is 0x 0
                ./veye_mipi_i2c.sh -b 10 -w -f mshutter -p1 0x44
                w mshutter is 0x44
                r mshutter is 0x 0
                or
                ./veye_mipi_i2c.sh -b 10 -r -f mirrormode
                r mirrormode is 0x 0
                ./veye_mipi_i2c.sh -b 10 -w -f mirrormode -p1 0x02
                w mirrormode is 0x 2
                Am I making a mistake somewhere?
                  @joe Please try putting -b 10 at the end of the command.
                  • J
                    I noticed that there is no difference when I change the order of '-b 10' to the end of the line in the command. I'm running the command from ~/nvidia_jetson_veye_bsp/i2c_cmd/bin; can you confirm if this path is correct? Additionally, I'm open to any alternative solutions or suggestions. Thanks in advance for your help!
                      From this point, your program reads hdver correctly.
                      However, based on the feedback from all your other scripts, it seems that both reading and writing cannot be executed properly.
                      Here are the commands and displays from my side. The difference is that the camera is connected to i2c-9.
                      How about you try recompiling i2c_read and i2c_write?
                      i2c_cmd/source/i2c_tools
                      • J
                        It work, after change the mipi connector! (I use -b 9.)
                        • J
                          joe @joe last edited by
                          @joe
                          It is indicated in the documents about "New function list" that:
                          "The following new features are only supported in camera's firmware versions with release time later than 2022-11-22."
                          My firmware version is exactly 2022-11-22. Is this version support "New function list"?
                            @joe yes
