SOLVED CS-LAMP-IR Frame Synchronization
 I am looking for a night vision sensor with IR board, and came across this product.
 One of my requirements is for energy efficiency - so illuminating the subject only when the sensor is capturing a frame helps with this.
 When in "night mode", does the lamp module synchronize it's pulses of IR light to the frame-sync of the sensor - or is the IR lamp running a full duty cycle?Thank you!
 @nimble99 Hi, this board won't work for you. It's a IR lamp running a full duty cycle.
