    SOLVED software trigger for MV-MIPI-SC130M
    • D
      dm last edited by
      How to make a long exposure on the MV-MIPI-SC130M camera? Is it possible to change the program code?
      Requires a software trigger to control exposure time up to 1 minute.
      Can any body help me?
        veye_xumm @dm last edited by
        @dm
        With today's camera firmware, the exposure time is limited by the minimum frame rate. To achieve long exposures, you first have to configure a very small frame rate, here are our measurements.
        • D
          dm @veye_xumm last edited by
          Thank you.
          Are the trigger pins of the sensor not connected to the device controller?
            @dm
            @dm said in software trigger for MV-MIPI-SC130M:
            The trigger pins of the sensor are connected to the device controller
