    UNSOLVED 树莓派64位连接CS-MIPI-IMX307问题
    Raspberry Pi App Software
    7788
    • F
      fancong @veye_xumm last edited by
      大神您好,按照这个文档,我加载驱动后重启,dmesg打印如下错误:
      fancong@raspberrypi:~$ dmesg | grep imx
      [ 0.067734] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/csimx307@3b
      [ 7.304776] csimx307: loading out-of-tree module taints kernel.
      [ 7.307571] csimx307 10-003b: supply VANA not found, using dummy regulator
      [ 7.307929] csimx307 10-003b: supply VDIG not found, using dummy regulator
      [ 7.308083] csimx307 10-003b: supply VDDL not found, using dummy regulator
      [ 7.316034] csimx307 10-003b: csimx307_identify_module: error during i2c read probe (-121)
      [ 7.317349] csimx307: probe of 10-003b failed with error -121
      我想知道,这个cs-mipi-imx307是否需要接红黑电源线,我看接线文档里面说不需要,imx307小板上面上电之后,会有啥表现吗?例如有指示灯之类的
        veye_xumm @fancong last edited by
        @fancong
        没有指示灯。
        不需要接红黑电源线。
        你看一下fpc线的方向,有没有接反了?
        或者拍一下fpc接口的照片我看看。
        • F
          @veye_xumm ![替代文字](screenshot-20240319-105841.png screenshot-20240319-105828.png 图片地址)
            @fancong 看起来树莓派那头插反了
            • F
              @veye_xumm 线没接错哦,我换了一个imx290,可以识别到:
              [ 0.068153] platform fe801000.csi: Fixed dependency cycle(s) with /soc/i2c0mux/i2c@1/imx290@1a
              [ 7.133686] csimx307: loading out-of-tree module taints kernel.
              [ 7.138194] csimx307 10-003b: supply VANA not found, using dummy regulator
              [ 7.150271] csimx307 10-003b: supply VDIG not found, using dummy regulator
              [ 7.150441] csimx307 10-003b: supply VDDL not found, using dummy regulator
              [ 7.158951] csimx307 10-003b: csimx307_identify_module: error during i2c read probe (-121)
              [ 7.159789] csimx307: probe of 10-003b failed with error -121
              [ 7.209372] imx290 10-001a: 16-bit write to 0x301c failed: -121
              [ 7.211146] imx290 10-001a: 24-bit write to 0x3020 failed: -121
              [ 7.212098] imx290 10-001a: 24-bit write to 0x3018 failed: -121
              [ 7.213639] imx290 10-001a: 24-bit write to 0x3020 failed: -121
              [ 7.213706] imx290 10-001a: Consider updating driver imx290 to match on endpoints
              • F
                @veye_xumm 有没有可能是相机固件需要重新刷?
                  @fancong 不需要重刷固件。如果排线方向没问题,那么有可能需要红黑线供电。
                  我现在不清楚你的底板的供电能力如何,你可以短时间用红黑线给307供电试一下。不要长期这么用。
                  回头测试完成告诉我结果。
                  • F
                    @veye_xumm 收到,我试试,谢谢大佬
                    • F
                      @veye_xumm 我试了一下,单独加上供电,也不行,我还原成老版本的32位系统看看吧
                      • F
                        @veye_xumm 还原成32位版本,也不能识别,这个是咋回事儿啊?老板大神,求指教
                        • F
                          @veye_xumm 相机接上红黑线之后,也在发热
                            @fancong
                            这个跟64位系统和32位系统没有关系,都能支持。
                            看你的提示,
                            显示i2c-10上面找不到摄像头。
                            你这个板子总共引出了几个camera接口? 确定测试307的时候是插到i2c-10的吗?
                            • F
                              @veye_xumm 一共只有一个CSI口和一个DSI口
                              • F
                                @veye_xumm 应该是插在CSI0了,如何选择哪个CSI呢?
                                  @fancong said in 树莓派64位连接CS-MIPI-IMX307问题:
                                  你调试290也是放在同一个CSI接口的吗? 是不是dtb有冲突啊?
                                  你把/boot/config.txt里面的内容贴出来我看看。你把/boot/config.txt中其他相机相关的东西注掉试试。
                                  • F
                                    @veye_xumm 我后面重新烧录了32位的了,没有290的驱动了,只是我们自己的cs-mipi-imx307的,新的打印如下:
                                    $ dmesg | grep imx
                                    [ 5.458365] csimx307: loading out-of-tree module taints kernel.
                                    [ 5.470420] csimx307 10-003b: csimx307_identify_module: error during i2c read probe (-121)
                                    [ 5.475082] csimx307: probe of 10-003b failed with error -121
                                    $ dmesg | grep csi
                                      @fancong 你的底板是自己做的对吧? 引出的是CM4的CAM1还是CAM0?对应的I2C是什么?
                                      • F
                                        @veye_xumm 不是自己做的,是买的第三方的
                                        • F
                                          @veye_xumm 我看你们文档里面有说明:
                                          "对于只有1个MIPI CSI-2口的树莓派主板,i2c总线序号是10。如果你的piOS很老,那么有可能是0。"
                                          默认是10吧
                                          • F
                                            fancong @veye_xumm last edited by fancong
                                            @veye_xumm 我换了一个树莓派4B,按照经典方案进行验证,可以得到如下信息,但是只有video10,没有video0:
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f devid
                                            hardwareid is 0x 2
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f hdver
                                            hardware logic version is 0x33
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f firmwarever
                                            r firmware version is 2.35
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f productmodel
                                            PRODUCT MODEL is CS-MIPI-IMX307
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f camcap
                                            r camera capbility 0x0005
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f videofmtcap
                                            camera support videofmt num 3
                                            r videofmtcap num 1 width 1920 height 1080 framerate 30
                                            r videofmtcap num 2 width 1280 height 720 framerate 60
                                            r videofmtcap num 3 width 640 height 480 framerate 130
                                            r old type videofmt width 1920 height 1080 framerate 30
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -w -f videofmt -p1 1920 -p2 1080 -p3 10
                                            w old videofmt width 1920 height 1080 framerate 10
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f ispcap
                                            r ispcap 0x17
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -w -f videofmt -p1 1920 -p2 1080 -p4 0.20
                                            w new type videofmt width 1920 height 1080 framerate 0.20
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -r -f i2caddr -d i2caddrnow
                                            r i2caddr 0xff
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -w -f i2caddr -p1 newi2caddr -d oldi2caddr
                                            ./cs_mipi_i2c.sh: line 586: printf: newi2caddr: invalid number
                                            w i2caddr 0x 0 and save
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -w -f paramsave
                                            pi@raspberrypi:bin$ ./cs_mipi_i2c.sh -w -f sysreset
                                            w sysreset,all param will reset
                                            这个能表示检测到了摄像头了吗? 但是为啥是video10呢?用的树莓派4B
