    SOLVED MV-MIPI-130M throw V-by-one
    Machine Vision camera
    • D
      Dan last edited by
      Hi, I am trying MV-MIPI-130M camera throw V-by-one kit and roc-rk3588s-pc. I use release v2.0 for rk3588s from github. If full resolution is used image stream not reacieved , and when roi is used image lines is sheefted to each other.
      The same kit with RAW-MIPI-SC132M works fine. I use gst-launch1.0 for tests. Is it any way to configure V-by-one kit for MV-MIPI-130M?
        veye_xumm @Dan last edited by
        @dan
        Please provide more details.
        What is the model of your motherboard?
        What image are you using?
        What commands did you use to invoke the image?
        • D
          Dan @veye_xumm last edited by
          Mothreboard is ROC-RK3588S-PC https://en.t-firefly.com/product/industry/rocrk3588spc
          Command for MV-MIPI-132M is gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=1280,height=1024,format=GRAY8,framerate=20/1 ! videoconvert ! xvimagesink
          Command fot RAW-MIPI-SC132M is gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,width=1024,height=1280,format=GRAY8,framerate=20/1 ! videoconvert ! xvimagesink
          Image pixel size is 8 bit, max aviable resolution for sensor is used
            @dan said in MV-MIPI-130M throw V-by-one:
            Please use this script for MV-MIPI-SC130M
            export I2C_BUS=7
            export WIDTH=1280
            export HEIGHT=1024
            export FPS=108
            media-ctl -d /dev/media0 --set-v4l2 '"m00_b_mvcam '"$I2C_BUS"'-003b":0[fmt:Y8_1X8/'"$WIDTH"'x'"$HEIGHT"'@1/'"$FPS"']'
            • D
              @veye_xumm Hi,
              I have used your script and got the same result, the Image is wrong for MV-MIPI-SC130M - low framerate, image is concatinated from parts of 2 diffrent frames.
              If resolution 720x512 is used, image framerate is good, but rows are sheefted reletive to each other
                @dan
                Please try this image.
                export I2C_BUS=7
                export WIDTH=1280
                export HEIGHT=1024
                export FPS=108
                v4l2-ctl -d /dev/video0 --set-fmt-video=width=$WIDTH,height=$HEIGHT,pixelformat=GREY --stream-mmap --stream-count=-1 --stream-to=/dev/null
