    SOLVED Install camera to rpi4
    Raspberry Pi App Software
    2349
    • V
      Viktor @veye_xumm last edited by Viktor
      I have tried:
      crosscompile kinux image veye327 driver for Ubuntu Desktop 21.04 Rpi4
      on rpi4
      uname -r
      5.11.0-1008-raspi
      uname -a
      Linux number 5.11.0-1008-raspi #8-Ubuntu SMP PREEMPT Thu May 6 17:46:38 UTC 2021 aarch64 aarch64 aarch64 GNU/Linux
      on host
      sudo apt install git bc bison flex libssl-dev make libc6-dev libncurses5-dev crossbuild-essential-arm64
      mkdir rpi_ubuntu_source
      cd rpi_ubuntu_source
      git clone --depth=1 git://git.launchpad.net/~ubuntu-kernel/ubuntu/+source/linux-raspi/+git/hirsute
      git clone https://github.com/veyeimaging/raspberrypi_v4l2.git
      cp raspberrypi_v4l2/driver_source/cam_drv_src/rpi-5.x_all/veye327.c hirsute/drivers/media/i2c
      edit hirsute/drivers/media/i2c/Kconfig
      find section imx219 and after it add:
      config VIDEO_VEYE327
      	tristate "VEYE VEYE327 sensor support"
      	depends on I2C && VIDEO_V4L2
      	select MEDIA_CONTROLLER
      	select VIDEO_V4L2_SUBDEV_API
      	select V4L2_FWNODE
      	help
      	  This is a Video4Linux2 sensor driver for the VEYE
      	  IMX327 camera.
      	  To compile this driver as a module, choose M here: the
      	  module will be called veye327.
      edit hirsute/drivers/media/i2c/Makefile
      find line imx219 and after it add:
      obj-$(CONFIG_VIDEO_VEYE327)	+= veye327.o
      cp raspberrypi_v4l2/driver_source/dts/rpi-5.10.y/veye327-overlay.dts hirsute/arch/arm64/boot/dts/overlays
      edit hirsute/arch/arm64/boot/dts/overlays/Makefile
      veye327.dtbo \
      build
      cd hirsute
      KERNEL=kernel8
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- bcm2711_defconfig
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- menuconfig
      got to Device Drivers --> Multimedia Support --> Media ancillary drivers --> Camera sensor devices
      select veye327 and save
      make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- Image modules dtbs -j4
      copy image and dtb
      on rpi4 replace vmlinuz-* with compiled hirsute/arch/arm64/boot/Image
      on rpi4 copy to /boot/firmware/overlays dtb file hirsute/arch/arm64/boot/dst/overlays/veye327.dtbo
      Before was imx219 connected and it works on Ubuntu Desktop 21.04 rpi4 as /dev/video0
      Was replaced imx219 to veye327E.
      After reboot rpi4 loaded but /dev/video0 gone.
      Can you help me to understand what files i need to copy?
      May be config, system.map, initrd or other dtb files?
      • V
        • V
          Viktor @Viktor last edited by
          Here is rpi boot contents:
          number@number:/boot$ ls
          config-5.11.0-1008-raspi  dtb-5.11.0-1008-raspi  grub
          System.map-5.11.0-1008-raspi
          config.txt
          dtbs
          initrd.img
          vmlinuz-5.11.0-1008-raspi
          dtb
          firmware
          initrd.img-5.11.0-1008-raspi
          • V
            Viktor @Viktor last edited by Viktor
            I tried installing veye327 to rpiOs.
            I have 5.10.36 firmware. veye drivers don't have this version.
            I tried build from source, but failed.
            Copied built zImage and veye327.dtbo to rpi and got load kernel modules failed on startup.
            Updated: i did modules_install and veye327 works on rpiOs now.
            Can you help build kernel for Ubuntu Desktop Rpi?
            • V
              I did it.
              on rpi4
              uname -r
              5.11.0-1008-raspi
              uname -a
              on host
              git clone --depth=1 git://git.launchpad.net/~ubuntu-kernel/ubuntu/+source/linux-raspi/+git/hirsute linux
              cp raspberrypi_v4l2/driver_source/cam_drv_src/rpi-5.x_all/veye327.c linux/drivers/media/i2c
              edit linux/drivers/media/i2c/Kconfig
              	select V4L2_FWNODE
              	help
              	  IMX327 camera.
              edit linux/drivers/media/i2c/Makefile
              cp raspberrypi_v4l2/driver_source/dts/rpi-5.10.y/veye327-overlay.dts linux/arch/arm64/boot/dts/overlays
              edit linux/arch/arm64/boot/dts/overlays/Makefile
              veye327.dtbo \
              build kernel
              cd linux
              KERNEL=kernel8
              go to Device Drivers --> Multimedia Support --> Media ancillary drivers --> Camera sensor devices
              mount sd to host
              mkdir mnt
              mkdir mnt/fat32
              mkdir mnt/ext4
              sudo mount /dev/sdd1 mnt/fat32
              sudo mount /dev/sdd2 mnt/ext4
              copy modules
              sudo env PATH=$PATH make ARCH=arm64 CROSS_COMPILE=aarch64-linux-gnu- INSTALL_MOD_PATH=mnt/ext4 modules_install
              copy kernel and dtb
              sudo cp mnt/fat32/vmlinuz mnt/fat32/vmlinuz.old
              sudo cp arch/arm64/boot/Image mnt/fat32/vmlinuz
              sudo cp arch/arm64/boot/dts/broadcom/*.dtb mnt/fat32/
              sudo cp arch/arm64/boot/dts/overlays/*.dtb* mnt/fat32/overlays/
              sudo cp arch/arm64/boot/dts/overlays/README mnt/fat32/overlays/
              sudo umount mnt/fat32
              sudo umount mnt/ext4
              on rpi4
              edit /boot/firmware/config.txt
              add lines
              gpu_mem=400
              dtparam=i2c_vc=on
              cma=128M
              dtoverlay=veye327.dtbo
              start_x=1
              sudo reboot
              dmesg | grep veye
              veye327 probed
              preview
              gst-launch-1.0 v4l2src device=/dev/video0 ! "video/x-raw,format=(string)UYVY, width=(int)1920, height=(int)1080,framerate=(fraction)30/1" ! videoconvert ! autovideosink sync=false text-overlay=false -v
              success
              V F 2 Replies Last reply Reply Quote 0
              • V
                Add to /etc/modules
                i2c-dev
                i2c bus 10,11 for sensor control
                  veye_xumm @Viktor last edited by
                  @viktor
                  Great! Thank you for trying and sharing.
                  • V
                    • F
                      fire @Viktor last edited by
                      @viktor
                      Thanks very much.
                      I wonder how did you set camera parameters, I found that the cs_mipi_i2c.sh not working.
                      • V
                        Viktor @fire last edited by
                        @fire Veye327 i2c fully works.
                        • F
                          @viktor
                          Can you use the original pi commands (e.g. raspistill raspivid), instead of using gst-launch?
                          • V
                            Viktor @fire last edited by Viktor
                            @fire Yes, raspivid and raspistill works too on Ubuntu.
