    UNSOLVED Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    Raspberry Pi App Software
    596
      veye_xumm @jambojettt last edited by
      @jambojettt
      Sorry for the slightly delayed reply. Normally, piOS comes with kernel-headers pre-installed. For example, here is a screenshot of my current system:
      I suspect that you might have updated to a newer minor version of piOS, which caused this issue. The current major version of piOS should be 6.12.47.
        • J
          jambojettt @veye_xumm last edited by
          @veye_xumm yes, it updated to 6.12.57, but this problem also was in 6.12.47 that it was updated from.
          How do I get the headers?
            @jambojettt said in Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+:
            My Raspberry Pi comes with headers by default. You might want to reinstall piOS? We've already released the 6.12.47 ko file on GitHub.
            • J
              • J
                jambojettt @jambojettt last edited by
                Kernel headers are installed.
                • J
                    @jambojettt
                    uname -a
                    ls /usr/lib/modules/
                    • J
                        @jambojettt
                        Sorry for reply late.
