    SOLVED Adjust framerate and shutter speed separtly
    1176
    • W
      watchever @veye_xumm last edited by
      @veye_xumm I use mshutter for shutter speed and lowlight for framerate.
        @watchever
        I have to say lowlight is not a method to adjust framerate. It's a exposure time parameter.
        Note that the set value is the minimum frame rate value and the actual frame rate value is affected by the automatic exposure algorithm.
        If you want to drop some frames, try nodf.
        • W
          @veye_xumm thanks, if I well understand nodf ignore some frames but not really reduce the material framerate. Am I wrong ?
          W veye_xumm 2 Replies Last reply Reply Quote 0
          • W
            watchever @watchever last edited by
            Is there a way to fully deactivate the auto exposure algorithm ? I think when I manually set mshutter it it the case ?
              @watchever
              @watchever said in Adjust framerate and shutter speed separtly:
              You are right.
                veye_xumm @watchever last edited by veye_xumm
                This statement is partially correct. The exposure time will be fully manual by setting mshutter, but gain is still automatic. You can set agc to 0 to force the automatic adjustment of gain to be turned off.
                • W
                  @veye_xumm thanks, I really need to reduce pixel refesh rate on the material side, is it possible ?
                    It's not supported for VEYE series.
                    CS series support this feature.
                    • W
                      @veye_xumm yes but CS series don't have same sensor and are not as sensitive as VEYE series (especially 462 and 327).
                      Is it a material limit or could be solved by a development on your side : add a specific register to set framerate ? Thanks
                        @watchever
                        Sorry, this can not be modified. IMX307 is slightly worse than 327 low illumination, but the actual difference is not very large.
