    UNSOLVED CS-MIPI-IMX307 not working on XAVIER NX release 32.6.1
    • T
      techies last edited by
      I followed the instructions found in http://wiki.veye.cc/index.php/VEYE_CS_Camera_for_Jetson_TX2
      My environment:
      cat /etc/nv_tegra_release
      R32 (release), REVISION: 6.1, GCID: 27863751, BOARD: t186ref, EABI: aarch64, DATE: Mon Jul 26 19:36:31 UTC 2021
      1. There seems to be a typo in the Image copy: it says,
        sudo cp <path to your Image dir>/Image /boot/Image -f
        sudo cp <path to your Image dir>/Image.sig /boot/Image -f
      I believe it should be:
      sudo cp <path to your Image dir>/Image.sig /boot/Image.sig -f
      In other words, the SIG file should be copied to the SIG file in /boot
      1. So I copied the correct Image and Image.sig files from Git to /boot, then I updated the extlinux.conf file:
        LABEL primary
        MENU LABEL primary kernel
        LINUX /boot/arducam/Image
        FDT /boot/tegra194-p3668-all-p3509-0000.dtb
        INITRD /boot/initrd
        APPEND ${cbootargs} quiet root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
      I didn't work! After reboot, ls /sys/bus/i2c/drivers/ does not show the new driver and ls /proc/device-tree/cam_i2cmux/i2c@* does not show the camera model.
      Please let me know what is the solution!
      T veye_xumm 2 Replies Last reply Reply Quote 0
      • T
        techies @techies last edited by
        @techies P.S. The text editor reformatted the extlinux.conf but the formatting on the Xavier NX is correct.
        LABEL primary
        INITRD /boot/initrd
          veye_xumm @techies last edited by
          @techies
          @techies said in CS-MIPI-IMX307 not working on XAVIER NX release 32.6.1:
          Yes,Thanks.
          Please write the following line to the end of the file.
          Did you use these files?
          Image_l4t_r32.6.1_veyecam_signed_4_xavier.tgz
          JetPack_4.6_Linux_JETSON_XAVIER_NX_TARGETS/*****//boot/tegra194-p3668-all-p3509-0000.dtb
          • T
            techies @veye_xumm last edited by
            @veye_xumm Yes, I made sure to use the signed version and used the file you mentioned. I made sure that the signed DTB file tegra194-p3668-all-p3509-0000.dtb was in the /boot directory.
            Also I edited the extlinux.conf file and the FDT line to the end, so it looks like this:
            TIMEOUT 30
            DEFAULT primary
            MENU TITLE L4T boot options
            LABEL primary
            INITRD /boot/initrd
            I did a reboot but it didn't work. I ran the command "ls /sys/bus/i2c/drivers/" but there was no imx307 directory present. Also I ran the command "ls /proc/device-tree/cam_i2cmux/i2c@*" but the camera model was not listed.
            Please let me know. Thanks!
              @techies
              Sorry reply finished. China took a 7 day holiday. We just got back to work.
              There is no tab in front of FDT.
