    UNSOLVED VEYE-MIPI-327 fdsrc not able to be read from.
    • N
      Nathan Sinclair last edited by Nathan Sinclair
      Hello
      I'm attempting to build a gstreamer pipeline to flip a video stream received from the VEYE-327.
      I've been working with the wiki provided for using on pi zero.
      This is what i currently have:
      ./veye_raspivid -n -b 4000000 -t 10000000 -o - | gst-launch-1.0 -v fdsrc ! videoflip method=clockwise ! videoconvert ! fbdevsink
      Which throws an error at fdsrc... I'm guessing from other tests that what is happening here is the gstreamer goes into a play state but can't play.
      This is the output.
      camera num -1
      mmal: mmal_component_enable w 1920 h 1080
      raspipreview_create com
      mmal: Splitter has 4 output port,you could use num 2,3 for extend
      mmal: file handle is stdout!
      mmal: running now!!
      mmal: wait_for_next_change: time out here !
      mmal: running stop!! 0
      Pipeline is PREROLLING ...
      (gst-launch-1.0:1414): GStreamer-CRITICAL **: 16:11:42.517: gst_segment_to_stream_time: assertion 'segment->format == format' failed
      ERROR: from element /GstPipeline:pipeline0/GstFdSrc:fdsrc0: Internal data stream error.
      Additional debug info:
      gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstFdSrc:fdsrc0:
      ERROR: pipeline doesn't want to preroll.
      Setting pipeline to NULL ...
      Freeing pipeline ...
