    SOLVED VEYE-MIPI-IMX327S installation issue on the Google coral dev board?
    • N
      Nigel Gardiner last edited by
      Hi There
      I followed your instructions for installing the VEYE-MIPI-IMX327S onto the Google coral dev board but when I navigate to /boot to
      sudo cp fsl-imx8mq-phanbell-<camera_name>.dtb fsl-imx8mq-phanbell.dtb
      as per your instructions no such file exists.
      The contents of the directory are as follows
      mendel@zippy-tang:/boot$ ls
      boot.scr fsl-imx8mm-columbia.dtb fsl-imx8mq-phanbell-m4.dtbo Image overlays.txt u-boot.imx
      config-4.14.98-imx fsl-imx8mq-phanbell.dtb fsl-imx8mq-yorktown.dtb lost+found System.map-4.14.98-imx vmlinuz-4.14.98-imx
      Any advice much appreciated.
      kind regards
      Nigel.
        veye_xumm @Nigel Gardiner last edited by
        @nigel-gardiner
        It looks like the command was executed successfully, but it didn't have an effect.
        I am now offering an alternative method, first pushing the deb file to the board and then just installing it manually.
        • on host pc
        mdt push linux-image-4.14.98-imx_12-2_arm64.deb
        mdt shell
        • you are in coral board now
        sudo dpkg -i linux-image-4.14.98-imx_12-2_arm64.deb
        • N
          Nigel Gardiner @veye_xumm last edited by
          Hi
          Thank you, that worked, camera is streaming now.
          Thanks for your help.
          regards
          Nigel.
            @nigel-gardiner
            You are welcome.
