SOLVED VEYE-MIPI-IMX327S installation issue on the Google coral dev board?
 Hi There I followed your instructions for installing the VEYE-MIPI-IMX327S onto the Google coral dev board but when I navigate to /boot to sudo cp fsl-imx8mq-phanbell-<camera_name>.dtb fsl-imx8mq-phanbell.dtb as per your instructions no such file exists. The contents of the directory are as follows mendel@zippy-tang:/boot$ ls
 boot.scr fsl-imx8mm-columbia.dtb fsl-imx8mq-phanbell-m4.dtbo Image overlays.txt u-boot.imx
 config-4.14.98-imx fsl-imx8mq-phanbell.dtb fsl-imx8mq-yorktown.dtb lost+found System.map-4.14.98-imx vmlinuz-4.14.98-imxAny advice much appreciated. kind regards
 Nigel.
 @nigel-gardiner
 It looks like the command was executed successfully, but it didn't have an effect.
 I am now offering an alternative method, first pushing the deb file to the board and then just installing it manually.- on host pc
 mdt push linux-image-4.14.98-imx_12-2_arm64.deb mdt shell- you are in coral board now
 sudo dpkg -i linux-image-4.14.98-imx_12-2_arm64.deb
 Hi Thank you, that worked, camera is streaming now.
 Thanks for your help.regards
 Nigel.
 @nigel-gardiner
 You are welcome.
