    VEYE-MIPI-327S gstreamer issue
    • S
      sebaszz last edited by
      I trying to get gstreamer working via UDP
      RPI side
      /home/pi/raspberrypi/veye_raspcam/bin/./veye_raspivid -b 4000000 -t 0 -o -  | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! udpsink host=192.168.0.208 port=7000 sync=false
      PC side (192.168.0.208:7000)
      gst-launch-1.0 -v udpsrc port=7000 ! gdpdepay ! rtph264depay ! avdec_h264 ! autovideosink sync=false
      I get the following error
      Any help is really appreciated!
        veye_xumm @sebaszz last edited by
        @sebaszz I suggest you to use tcp, it is more stable.
        • S
          sebaszz @veye_xumm last edited by sebaszz
          I tried. Without succes. Any suggestions?
          RPI side (192.168.0.163)
          ./veye_raspivid -b 4000000 -t 0 -o -  | gst-launch-1.0 -v fdsrc ! h264parse ! rtph264pay config-interval=1 pt=96 ! gdppay ! tcpserversink host=192.168.0.208 port=7000
          PC side (192.168.0.208)
          gst-launch-1.0 -v tcpclientsrc host=192.168.0.163 port=7000 ! gdpdepay ! rtph264depay ! avdec_h264 ! autovideosink sync=false
          ERROR GSTREAMER
          (gst-launch-1.0:5064): GStreamer-WARNING **: 21:15:29.964: Failed to load plugin 'C:\gstreamer\1.0\msvc_x86\lib\gstreamer-1.0\gstwavpack.dll': The specified module could not be found.
          This usually means Windows was unable to find a DLL dependency of the plugin. Please check that PATH is correct.
          You can run 'dumpbin -dependents' (provided by the Visual Studio developer prompt) to list the DLL deps of any DLL.
          There are also some third-party GUIs to list and debug DLL dependencies recursively.
          Use Windows high-resolution clock, precision: 1 ms
          ERROR: from element /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0: Could not open resource for reading.
          Additional debug info:
          ../gst/tcp/gsttcpclientsrc.c(493): gst_tcp_client_src_start (): /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0:
          Failed to connect to host '192.168.0.163:7000': No connection could be made because the target machine actively refused it.
          ERROR: pipeline doesn't want to preroll.
          ERROR: from element /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
          ../libs/gst/base/gstbasesrc.c(3557): gst_base_src_start (): /GstPipeline:pipeline0/GstTCPClientSrc:tcpclientsrc0:
          Failed to start
          Failed to set pipeline to PAUSED.
          Setting pipeline to NULL ...
          Freeing pipeline ...
          ERROR RPI
          14/06/2022 20:15:22 Enabling custom
          Pipeline is PREROLLING ...
          ERROR: from element /GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0: Could not open resource for reading.
          gsttcpserversink.c(403): gst_tcp_server_sink_init_send (): /GstPipeline:pipeline0/GstTCPServerSink:tcpserversink0:
          Failed to bind on host '192.168.0.208:7000': Error binding to address: Cannot assign requested address
          mmal: mmal_vc_port_enable: failed to enable port vc.ril.isp:in:0(UYVY): ENOMEM
          mmal: mmal_port_enable: failed to enable connected port (vc.ril.isp:in:0(UYVY))0x1bfef00 (ENOMEM)
          mmal: mmal_connection_enable: output port couldn't be enabled
          mmal: Failed to create rawcam->isp connection
          mmal: Out of memory
          mmal: Camera is not detected. Please check carefully the camera module is installed correctly
          • S
            sebaszz last edited by sebaszz
            I prefer to have a UDP working since it will be used after testing via 4G/LTE connection.
            All these test are currently done via Wifi. Standard Pi camera is working fine.
              @sebaszz said in VEYE-MIPI-327S gstreamer issue:
              Please use rpi ip addr in this cmd too.
              • S
                FIXED! thank you!
