    SOLVED veye_mvcam: disagrees about version of symbol module_layout
    1093
    • F
      ff1211 last edited by ff1211
      根据此处的教程而来,最后一步检查系统状态时候和教程结果不一致。
      相机是MV-MIPI-SC130M。
      内核版本
      Linux raspberrypi 5.15.61-v8+ #1579 SMP PREEMPT Fri Aug 26 11:16:44 BST 2022 aarch64 GNU/Linux
        @ff1211
        这个提示可以忽略。 你插好camera,注意一下ffc cable的方向。 然后继续往下走走看。
        • F
          @veye_xumm 输入v4l2-ctl --list-formats-ext后,得到Cannot open device /dev/video0, exiting.
            @ff1211
            下面这个命令输出得到什么结果?
            dmesg | grep mvcam
            • F
              @veye_xumm 还想问下mv_mipi_i2c.sh这个文件在哪,我在你们git仓库里没搜索到。
                @ff1211
                https://github.com/veyeimaging/mvcam_raspberrypi
                • F
                  @veye_xumm said in veye_mvcam: disagrees about version of symbol module_layout:
                  dmesg | grep mvcam
                  [ 6.743382] veye_mvcam: disagrees about version of symbol module_layout
                  [ 6.835960] veye_mvcam: disagrees about version of symbol module_layout
                  [ 6.880028] veye_mvcam: disagrees about version of symbol module_layout
                    @ff1211 said in veye_mvcam: disagrees about version of symbol module_layout:
                    建议你参考这个文章,重新编译驱动,然后安装一下。
                    http://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh
                    • F
                      @veye_xumm 我试下
                      • F
                        @veye_xumm 您好,我尝试了下检测iic接口,输入 i2cdetect -y 1后显示的都是横线,网上说是没有检测到iic设备,是不是因为这个原因?排线没有接好或者还需要单独接iic线吗?
                          @ff1211 树莓派应该是i2c10吧
                          • F
                            @veye_xumm 您好,我重新编译之后,显示这个,正常了吗?
                            [ 8.164689] veye_mvcam: loading out-of-tree module taints kernel.
                            [ 8.859832] mvcam 10-003b: camera is: MV-MIPI-SC130M
                            [ 8.861876] mvcam 10-003b: firmware version: 0x1260132
                            [ 8.882341] mvcam 10-003b: Consider updating driver mvcam to match on endpoints
                              @ff1211 没问题,搞定了。
                              • F
                                @veye_xumm 感谢
