    SOLVED veye_mvcam: disagrees about version of symbol module_layout
    1869
    • F
      @veye_xumm 还想问下mv_mipi_i2c.sh这个文件在哪,我在你们git仓库里没搜索到。
        @ff1211
        https://github.com/veyeimaging/mvcam_raspberrypi
        • F
          @veye_xumm said in veye_mvcam: disagrees about version of symbol module_layout:
          dmesg | grep mvcam
          [ 6.743382] veye_mvcam: disagrees about version of symbol module_layout
          [ 6.835960] veye_mvcam: disagrees about version of symbol module_layout
          [ 6.880028] veye_mvcam: disagrees about version of symbol module_layout
            @ff1211 said in veye_mvcam: disagrees about version of symbol module_layout:
            建议你参考这个文章,重新编译驱动,然后安装一下。
            http://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh
            • F
              @veye_xumm 我试下
              • F
                @veye_xumm 您好,我尝试了下检测iic接口,输入 i2cdetect -y 1后显示的都是横线,网上说是没有检测到iic设备,是不是因为这个原因?排线没有接好或者还需要单独接iic线吗?
                  @ff1211 树莓派应该是i2c10吧
                  • F
                    @veye_xumm 您好,我重新编译之后,显示这个,正常了吗?
                    [ 8.164689] veye_mvcam: loading out-of-tree module taints kernel.
                    [ 8.859832] mvcam 10-003b: camera is: MV-MIPI-SC130M
                    [ 8.861876] mvcam 10-003b: firmware version: 0x1260132
                    [ 8.882341] mvcam 10-003b: Consider updating driver mvcam to match on endpoints
                      @ff1211 没问题,搞定了。
                      • F
                        @veye_xumm 感谢
