    SOLVED VEYE-MIPI-IMX462 - manual gain not consistent
    3456
    • M
      milank @veye_xumm last edited by
      for this, please see:
      https://github.com/CroatianMeteorNetwork/RMS/blob/master/Utils/PlotFieldsums.py
        veye_xumm @milank last edited by veye_xumm
        @milank
        I have provided a script in the attachment which can read the sensor registers.
        Can you please add a monitoring program in your system to monitor the following registers of the sensor: 0x14, 0x20, 0x21, 0x22, and 0x09.
        The usage of the script is: ./veye_inner.sh -r -f sns_reg -p1 [sns_reg_addr].
        Especially pay attention to whether the registers of the sensor have changed when a sudden change in brightness is detected.
        veye_inner.sh.txt
        • M
          fine, understood, now it is running in the background for spoken registers.
          I will come back with the results once I see the spike again.
          • M
            milank @milank last edited by
            @milank
            Another change has been detected last night, around 20:44:25 UTC.
            Unfortunatelly, no change detected in spoken registers.
            The reading interval was set to 5 seconds.
            I am also attaching two full BMP images just before/after the change of brightness.![1_1678948719448_FF_CZ0004_20230315_204426_226_0277248.fits_maxpixel.bmp](Nahrávám 100%) ![0_1678948719448_FF_CZ0004_20230315_204416_011_0276992.fits_maxpixel.bmp](Nahrávám 100%)
            03/15/2023 20:44:11 reg addr 0x14 val is 0x53
            03/15/2023 20:44:11 reg addr 0x20 val is 0x1
            03/15/2023 20:44:11 reg addr 0x21 val is 0x0
            03/15/2023 20:44:11 reg addr 0x22 val is 0x0
            03/15/2023 20:44:12 reg addr 0x9 val is 0x11
            03/15/2023 20:44:17 reg addr 0x14 val is 0x53
            03/15/2023 20:44:17 reg addr 0x20 val is 0x1
            03/15/2023 20:44:18 reg addr 0x21 val is 0x0
            03/15/2023 20:44:18 reg addr 0x22 val is 0x0
            03/15/2023 20:44:18 reg addr 0x9 val is 0x11
            03/15/2023 20:44:24 reg addr 0x14 val is 0x53
            03/15/2023 20:44:24 reg addr 0x20 val is 0x1
            03/15/2023 20:44:24 reg addr 0x21 val is 0x0
            03/15/2023 20:44:25 reg addr 0x22 val is 0x0
            03/15/2023 20:44:25 reg addr 0x9 val is 0x11
            03/15/2023 20:44:30 reg addr 0x14 val is 0x53
            03/15/2023 20:44:30 reg addr 0x20 val is 0x1
            03/15/2023 20:44:31 reg addr 0x21 val is 0x0
            03/15/2023 20:44:31 reg addr 0x22 val is 0x0
            03/15/2023 20:44:31 reg addr 0x9 val is 0x11
            03/15/2023 20:44:36 reg addr 0x14 val is 0x53
            03/15/2023 20:44:37 reg addr 0x20 val is 0x1
            03/15/2023 20:44:37 reg addr 0x21 val is 0x0
            03/15/2023 20:44:37 reg addr 0x22 val is 0x0
            03/15/2023 20:44:38 reg addr 0x9 val is 0x11
            03/15/2023 20:44:43 reg addr 0x14 val is 0x53
            03/15/2023 20:44:43 reg addr 0x20 val is 0x1
            03/15/2023 20:44:43 reg addr 0x21 val is 0x0
            03/15/2023 20:44:44 reg addr 0x22 val is 0x0
            03/15/2023 20:44:44 reg addr 0x9 val is 0x11
            • M
              @milank
              FF_CZ0004_20230315_204426_226_0277248.fits_maxpixel.jpg FF_CZ0004_20230315_204416_011_0276992.fits_maxpixel.jpg
                @milank
                Hi, we guess it might have something to do with an "extra" gain in ISP, which is a bug in new_expmode that doesn't completely turn off the automatic control of the image in ISP.
                You can try to configure it with this command and then test it again
                . /veye_mipi_i2c.sh -w -f brightness -p10
                BTW,since you are using the camera to capture the starry sky, it is recommended that you run the following script to turn off the automatic bad point correction.
                ./i2c_write 10 0x3b 0x0007 0xFE
                ./i2c_write 10 0x3b 0x0010 0xDB
                ./i2c_write 10 0x3b 0x0011 0x9F
                ./i2c_write 10 0x3b 0x0012 0x00
                ./i2c_read 10 0x3b 0x0014 1
                • M
                  fine, thank you, I will test, my init script now looks like:
                  sleep 1
                  sleep 1
                  ./veye_mipi_i2c.sh -w -f new_mgain -p1 23 # between 20 and 25
                  sleep 1
                  ./veye_mipi_i2c.sh -w -f brightness -p1 0
                  sleep 1
                  special code for sky imaging, to turn automatic bad point correction off
                  sleep 1
                    @milank Okay, looking forward to the results of your test.
                    • M
                      Hello,
                      now, it seems that this additional line did the trick.
                      No brightness drop seen anymore.
                      Thank you for your help.
                        @milank OK. You are welcome.
