    SOLVED New Raspberry pi 5 support
    5890
    • V
      Vaa @veye_xumm last edited by
      @veye_xumm Are you going to improve your driver's compatibility?
      • A
        • A
          • A
            Also after every RPi restart have to run script: ./media_setting_rpi5.sh veyecam2m
            @veye_xumm any chances use configuration script ./veye_mipi_i2c.sh on RPi5?
              veye_xumm @Vaa last edited by
              @vaa
                @alex_ai
                V A 2 Replies Last reply Reply Quote 0
                • V
                    @vaa
                    • V
                      Vaa @veye_xumm last edited by Vaa
                      Here is a receipt how can I achived this:
                      1. ./media_setting_rpi5.sh veyecam2m
                      2. ./veye_mipi_i2c.sh -b 6 -w -f yuvseq -p1 YUYV
                      3. ./veye_mipi_i2c.sh -b 6 -w -f videoformat -p1 PAL
                      4. In my app open device /dev/video0 with following parameters:
                        width 1920;
                        height 1080;
                        field_format V4L2_FIELD_NONE
                      Some other applications like gstreamer only set pixel_format if you directly point to do this, this is why it works, but many others (e.g. trying to set default pixel_format) are not.
                      V 1 Reply Last reply Reply Quote 1
                      • A
                        @veye_xumm said in New Raspberry pi 5 support:
                        @alex_ai
                        I think answer was "yes" but with parameter -b. I could not execute from bin dir because it compiled to another OS, so compile i2c_read, i2c_write from source code fixed my issue.
                        @veye_xumm thank you for help and support!
                          @alex_ai You are welcome.
                          • V
                            Vaa @Vaa last edited by
                            Will you going to fix the issue?
