    21794
    • O
      @veye_xumm Hi i have read all the wiki and downloaded https://github.com/veyeimaging/nvidia_jetson_veye_bsp
      but I am still missing dtb file for MV-MIPI-IMX264.
      I have bought 4 of them and I have tried so many times. still I cannot make use of one of those.
      I have install all the drivers and other steps i just need dtb file
      OS: ubuntu 22.04
      jeton orin nano Jetpack6.0,L4T r36.3
      please help me
      thanks
      • O
        Otca @Otca last edited by
        @otca
        cat /etc/nv_tegra_release
        R36 (release), REVISION: 3.0, GCID: 36191598, BOARD: generic, EABI: aarch64, DATE: Mon May 6 17:34:21 UTC 2024
        KERNEL_VARIANT: oot
        dmesg | grep -i 'fail'
        [ 5.067860] hid-generic: probe of 0003:1C4F:0202.0002 failed with error -22
        [ 9.577266] videodev: module verification failed: signature and/or required key missing - tainting kernel
        [ 11.795964] dce: dce_admin_setup_clients_ipc:561 Get queue info failed for [2]
        [ 12.536169] veye_mvcam: mvcam_read: Reading register 0x04 failed
        [ 12.536185] mvcam 9-0010: failed to read chip id
        [ 12.536190] mvcam 9-0010: mvcam_identify_module failed.
        [ 13.041253] veye_mvcam: mvcam_read: Reading register 0x04 failed
        [ 13.041269] mvcam 10-0010: failed to read chip id
        [ 13.041273] mvcam 10-0010: mvcam_identify_module failed.
        [ 16.965874] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call cmd:0x731341 result 0xffff:
        dmesg | grep -i 'veye'
        [ 12.031976] mvcam 9-0010: veye mv series camera driver version: 01.01.04
        [ 12.539516] mvcam 10-0010: veye mv series camera driver version: 01.01.04
        dmesg | grep -i 'error'
        [ 9.363672] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
        [ 9.365895] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
        [ 9.369376] squashfs: SQUASHFS error: Xattrs in filesystem, these will be ignored
          From this prompt message, it looks like your driver and dtb are doing the right thing. But now i2c probe can't get the device.
          Please make sure your 5V dupont cable is plugged into the right place? I can't see it clearly from the picture.
          • O
            5V dupon
            Thnaks for fast replay
            To double check the pin of IMX264 would u please tell me which one is 5V and which one is GND?
            • O
              @otca I just checked the connection and I'm sure that 5V and GND connection are OK.
              any idea what to do?
              • O
                @otca let double check the DTB i must use.
                My camera is MV-IMX264-M which one of these dtbo is the right one?
                tegra234-camera-rbpcv3-csimx307.dtsi*
                tegra234-camera-rbpcv3-cssc132.dtsi*
                tegra234-camera-rbpcv3-veyecam2m.dtsi*
                tegra234-camera-rbpcv3-veyeimx335.dtsi*
                tegra234-camera-rbpcv3-veye_mvcam.dtsi*
                tegra234-p3767-camera-p3768-csimx307-dual.dtbo*
                tegra234-p3767-camera-p3768-csimx307-dual.dts*
                tegra234-p3767-camera-p3768-cssc132-dual.dtbo*
                tegra234-p3767-camera-p3768-cssc132-dual.dts*
                tegra234-p3767-camera-p3768-raw_ar0234m-dual.dtbo*
                tegra234-p3767-camera-p3768-raw_ar0234m-dual.dts*
                tegra234-p3767-camera-p3768-raw_imx462m-dual.dtbo*
                tegra234-p3767-camera-p3768-raw_imx462m-dual.dts*
                tegra234-p3767-camera-p3768-veyecam2m-dual.dtbo*
                tegra234-p3767-camera-p3768-veyecam2m-dual.dts*
                tegra234-p3767-camera-p3768-veyeimx335-dual.dtbo*
                tegra234-p3767-camera-p3768-veyeimx335-dual.dts*
                tegra234-p3767-camera-p3768-veye_mvcam-dual.dtbo*
                tegra234-p3767-camera-p3768-veye_mvcam-dual.dts*
                    @otca
                    • O
                      TIMEOUT 50
                      DEFAULT JetsonIO
                      MENU TITLE L4T boot options
                      LABEL primary
                      MENU LABEL primary kernel
                      LINUX /boot/Image
                      INITRD /boot/initrd
                      LABEL recovery
                      LINUX /boot/Image
                      INITRD /boot/initrd
                      LINUX /boot/Image
                      INITRD /boot/initrd
                      LABEL Multi-User-With-GUI
                      LINUX /boot/Image
                      INITRD /boot/initrd
                      LABEL JetsonIO
                      LINUX /boot/Image
                      INITRD /boot/initrd
                      • O
                        		i2c@0 {
                        			reg = <0x00>;
                        			#address-cells = <0x01>;
                        			#size-cells = <0x00>;
                        			rbpcv3_mvcam_a@3b {
                        				reg = <0x3b>;
                        				devnode = "video0";
                        				physical_w = "5.6";
                        				physical_h = "3.1";
                        				sensor_model = "mvcam";
                        				use_sensor_mode_id = "false";
                        				status = "okay";
                        				phandle = <0x482>;
                        				mode0 {
                        					mclk_khz = "24000";
                        					num_lanes = "2";
                        					phy_mode = "DPHY";
                        					discontinuous_clk = "yes";
                        					dpcm_enable = "false";
                        					cil_settletime = "0";
                        					lane_polarity = "6";
                        					active_w = "3088";
                        					active_h = "2064";
                        					mode_type = "raw";
                        					csi_pixel_bit_depth = "8";
                        					pixel_phase = "y8";
                        					readout_orientation = "0";
                        					line_length = "3088";
                        					inherent_gain = "1";
                        					mclk_multiplier = "2";
                        					pix_clk_hz = "375000000";
                        					gain_factor = "16";
                        					framerate_factor = "1000000";
                        					exposure_factor = "1000000";
                        					min_gain_val = "16";
                        					max_gain_val = "170";
                        					step_gain_val = "1";
                        					default_gain = "16";
                        					min_hdr_ratio = "1";
                        					max_hdr_ratio = "1";
                        					min_framerate = "2000000";
                        					max_framerate = "20000000";
                        					step_framerate = "1";
                        					min_exp_time = "13";
                        					max_exp_time = "333333";
                        					step_exp_time = "1";
                        					default_exp_time = "2495";
                        Property IMX264
                        physical_w 8.390
                        physical_h 7.066
                        active_w 2432
                        active_h 2048
                        pixel_t RG 8,10,12
                        max_gain_val 48
                        step_gain_val 0.100
                        max_framerate (2L08) 35.5
                        max_framerate (2L10) 35.5
                        max_framerate (2L12) 35.5
                        Thanks for ur help ❤
                        • O
                          dmesg | grep -i 'i2c'
                            @otca
                              @otca
                              • O
                                • O
                                    @otca
                                    • O
                                        @otca
                                        • O
                                          • O
                                            Do u know this issue?
