    21794
    • O
      TIMEOUT 50
      DEFAULT JetsonIO
      MENU TITLE L4T boot options
      LABEL primary
      MENU LABEL primary kernel
      LINUX /boot/Image
      INITRD /boot/initrd
      LABEL recovery
      LINUX /boot/Image
      INITRD /boot/initrd
      LINUX /boot/Image
      INITRD /boot/initrd
      LABEL Multi-User-With-GUI
      LINUX /boot/Image
      INITRD /boot/initrd
      LABEL JetsonIO
      LINUX /boot/Image
      INITRD /boot/initrd
      • O
        		i2c@0 {
        			reg = <0x00>;
        			#address-cells = <0x01>;
        			#size-cells = <0x00>;
        			rbpcv3_mvcam_a@3b {
        				reg = <0x3b>;
        				devnode = "video0";
        				physical_w = "5.6";
        				physical_h = "3.1";
        				sensor_model = "mvcam";
        				use_sensor_mode_id = "false";
        				status = "okay";
        				phandle = <0x482>;
        				mode0 {
        					mclk_khz = "24000";
        					num_lanes = "2";
        					phy_mode = "DPHY";
        					discontinuous_clk = "yes";
        					dpcm_enable = "false";
        					cil_settletime = "0";
        					lane_polarity = "6";
        					active_w = "3088";
        					active_h = "2064";
        					mode_type = "raw";
        					csi_pixel_bit_depth = "8";
        					pixel_phase = "y8";
        					readout_orientation = "0";
        					line_length = "3088";
        					inherent_gain = "1";
        					mclk_multiplier = "2";
        					pix_clk_hz = "375000000";
        					gain_factor = "16";
        					framerate_factor = "1000000";
        					exposure_factor = "1000000";
        					min_gain_val = "16";
        					max_gain_val = "170";
        					step_gain_val = "1";
        					default_gain = "16";
        					min_hdr_ratio = "1";
        					max_hdr_ratio = "1";
        					min_framerate = "2000000";
        					max_framerate = "20000000";
        					step_framerate = "1";
        					min_exp_time = "13";
        					max_exp_time = "333333";
        					step_exp_time = "1";
        					default_exp_time = "2495";
        Property IMX264
        physical_w 8.390
        physical_h 7.066
        active_w 2432
        active_h 2048
        pixel_t RG 8,10,12
        max_gain_val 48
        step_gain_val 0.100
        max_framerate (2L08) 35.5
        max_framerate (2L10) 35.5
        max_framerate (2L12) 35.5
        Thanks for ur help ❤
        • O
          Otca @Otca last edited by
          dmesg | grep -i 'fail'
          dmesg | grep -i 'i2c'
          dmesg | grep -i 'veye'
            @otca
              @otca
              • O
                • O
                    @otca
                    • O
                        @otca
                        • O
                          • O
                            Do u know this issue?
                            • O
                                • O
                                  i2cdetect -y -r 9
                                  70: -- -- -- -- -- -- -- --
                                  i2cdetect -y -r 10
                                  ls /sys/bus/i2c/drivers/
                                  extLinux Config
                                  LABEL imx264
                                     LINUX /boot/Image
                                     INITRD /boot/initrd
                                  Upgarde Jetson Jetpack 6
                                  sudo depmod
                                  tegra-camera.ko
                                    @otca
                                    veye_xumm O 2 Replies Last reply Reply Quote 0
                                      @Otca
                                      • O
                                        thanks for your guidance.
                                        The dmesg log is appended.
                                        MV-MIPI-IMX264.txt
                                          • O
                                            Thanks alot
