    21795
    • O
        @otca
        • O
          • O
            Otca @Otca last edited by
            Do u know this issue?
            • O
                • O
                  i2cdetect -y -r 9
                  70: -- -- -- -- -- -- -- --
                  i2cdetect -y -r 10
                  ls /sys/bus/i2c/drivers/
                  extLinux Config
                  LABEL imx264
                     LINUX /boot/Image
                     INITRD /boot/initrd
                  Upgarde Jetson Jetpack 6
                  sudo depmod
                  tegra-camera.ko
                    @otca
                    veye_xumm O 2 Replies Last reply Reply Quote 0
                      @Otca
                      • O
                        thanks for your guidance.
                        The dmesg log is appended.
                        MV-MIPI-IMX264.txt
                          • O
                            Thanks alot
                              @otca
                              • O
                                here is dmesg log.
                                sudo dmesg| grep -i 'mvcam'
                                Full DMESG Log:
                                IMX264.OrinNX.txt
                                i2cdetect -y -r 10
                                VLC:
                                vlc
                                Opening in BLOCKING MODE
                                DTB :
                                TIMEOUT 30
                                DEFAULT imx264
                                MENU TITLE L4T boot options
                                LABEL primary
                                      MENU LABEL primary kernel
                                      LINUX /boot/Image
                                      INITRD /boot/initrd
                                LABEL imx264
                                      LINUX /boot/Image
                                      INITRD /boot/initrd
                                O veye_xumm 2 Replies Last reply Reply Quote 0
                                • O
                                  • O
                                    Dmesg Logs
                                    Dmesg_01.txt
                                    v4l2-ctl --list-formats-ext
                                    ioctl: VIDIOC_ENUM_FMT
                                    	Type: Video Capture
                                    	[0]: 'GREY' (8-bit Greyscale)
                                    		Size: Discrete 1920x1080
                                      @otca
                                      export WIDTH=2432
                                      export HEIGHT=2056
                                      export FPS=28
                                      v4l2-ctl --set-ctrl roi_x=0
                                      v4l2-ctl --set-ctrl roi_y=0
                                      • O
                                        @veye_xumm Hi,
                                        this is the results:
                                        export WIDTH=2432
                                        export HEIGHT=2056
                                        export FPS=28
                                        Dmesg log:
                                        ####Dmesg of Last Line:
                                        Full Dmesg log:
                                        Dmesg.txt
                                          • O
                                            sure!
