    21794
    • O
      • O
        Otca @Otca last edited by
          @otca
          • O
              @otca
              • O
                • O
                  Do u know this issue?
                  • O
                      • O
                        i2cdetect -y -r 9
                        70: -- -- -- -- -- -- -- --
                        i2cdetect -y -r 10
                        ls /sys/bus/i2c/drivers/
                        extLinux Config
                        LABEL imx264
                           LINUX /boot/Image
                           INITRD /boot/initrd
                        Upgarde Jetson Jetpack 6
                        sudo depmod
                        tegra-camera.ko
                          @otca
                          veye_xumm O 2 Replies Last reply Reply Quote 0
                            @Otca
                            • O
                              thanks for your guidance.
                              The dmesg log is appended.
                              MV-MIPI-IMX264.txt
                                • O
                                  Thanks alot
                                    @otca
                                    • O
                                      here is dmesg log.
                                      sudo dmesg| grep -i 'mvcam'
                                      Full DMESG Log:
                                      IMX264.OrinNX.txt
                                      i2cdetect -y -r 10
                                      VLC:
                                      vlc
                                      Opening in BLOCKING MODE
                                      DTB :
                                      TIMEOUT 30
                                      DEFAULT imx264
                                      MENU TITLE L4T boot options
                                      LABEL primary
                                            MENU LABEL primary kernel
                                            LINUX /boot/Image
                                            INITRD /boot/initrd
                                      LABEL imx264
                                            LINUX /boot/Image
                                            INITRD /boot/initrd
                                      O veye_xumm 2 Replies Last reply Reply Quote 0
                                      • O
                                        • O
                                          Dmesg Logs
                                          Dmesg_01.txt
                                          v4l2-ctl --list-formats-ext
                                          ioctl: VIDIOC_ENUM_FMT
                                          	Type: Video Capture
                                          	[0]: 'GREY' (8-bit Greyscale)
                                          		Size: Discrete 1920x1080
                                            @otca
                                            export WIDTH=2432
                                            export HEIGHT=2056
                                            export FPS=28
                                            v4l2-ctl --set-ctrl roi_x=0
                                            v4l2-ctl --set-ctrl roi_y=0
