    21794
      @otca
      • O
        • O
          Otca @Otca last edited by
          Do u know this issue?
          • O
              • O
                i2cdetect -y -r 9
                70: -- -- -- -- -- -- -- --
                i2cdetect -y -r 10
                ls /sys/bus/i2c/drivers/
                extLinux Config
                LABEL imx264
                   LINUX /boot/Image
                   INITRD /boot/initrd
                Upgarde Jetson Jetpack 6
                sudo depmod
                tegra-camera.ko
                  @otca
                  veye_xumm O 2 Replies Last reply Reply Quote 0
                    @Otca
                    • O
                      thanks for your guidance.
                      The dmesg log is appended.
                      MV-MIPI-IMX264.txt
                        • O
                          Thanks alot
                            @otca
                            • O
                              here is dmesg log.
                              sudo dmesg| grep -i 'mvcam'
                              Full DMESG Log:
                              IMX264.OrinNX.txt
                              i2cdetect -y -r 10
                              VLC:
                              vlc
                              Opening in BLOCKING MODE
                              DTB :
                              TIMEOUT 30
                              DEFAULT imx264
                              MENU TITLE L4T boot options
                              LABEL primary
                                    MENU LABEL primary kernel
                                    LINUX /boot/Image
                                    INITRD /boot/initrd
                              LABEL imx264
                                    LINUX /boot/Image
                                    INITRD /boot/initrd
                              O veye_xumm 2 Replies Last reply Reply Quote 0
                              • O
                                • O
                                  Dmesg Logs
                                  Dmesg_01.txt
                                  v4l2-ctl --list-formats-ext
                                  ioctl: VIDIOC_ENUM_FMT
                                  	Type: Video Capture
                                  	[0]: 'GREY' (8-bit Greyscale)
                                  		Size: Discrete 1920x1080
                                    @otca
                                    export WIDTH=2432
                                    export HEIGHT=2056
                                    export FPS=28
                                    v4l2-ctl --set-ctrl roi_x=0
                                    v4l2-ctl --set-ctrl roi_y=0
                                    • O
                                      @veye_xumm Hi,
                                      this is the results:
                                      export WIDTH=2432
                                      export HEIGHT=2056
                                      export FPS=28
                                      Dmesg log:
                                      ####Dmesg of Last Line:
                                      Full Dmesg log:
                                      Dmesg.txt
                                        • O
                                          sure!
                                            @otca
