    14971
      • O
        Thanks alot
          @otca
          • O
            here is dmesg log.
            sudo dmesg| grep -i 'mvcam'
            Full DMESG Log:
            IMX264.OrinNX.txt
            i2cdetect -y -r 10
            70: -- -- -- -- -- -- -- --
            VLC:
            vlc
            Opening in BLOCKING MODE
            DTB :
            TIMEOUT 30
            DEFAULT imx264
            MENU TITLE L4T boot options
            LABEL primary
                  MENU LABEL primary kernel
                  LINUX /boot/Image
                  INITRD /boot/initrd
            LABEL imx264
                  LINUX /boot/Image
                  INITRD /boot/initrd
            ls /sys/bus/i2c/drivers/
            O veye_xumm 2 Replies Last reply Reply Quote 0
            • O
              Otca @Otca last edited by
              • O
                Dmesg Logs
                Dmesg_01.txt
                v4l2-ctl --list-formats-ext
                ioctl: VIDIOC_ENUM_FMT
                	Type: Video Capture
                	[0]: 'GREY' (8-bit Greyscale)
                		Size: Discrete 1920x1080
                  @otca
                  export WIDTH=2432
                  export HEIGHT=2056
                  export FPS=28
                  v4l2-ctl --set-ctrl roi_x=0
                  v4l2-ctl --set-ctrl roi_y=0
                  • O
                    @veye_xumm Hi,
                    this is the results:
                    export WIDTH=2432
                    export HEIGHT=2056
                    export FPS=28
                    Dmesg log:
                    ####Dmesg of Last Line:
                    Full Dmesg log:
                    Dmesg.txt
                      • O
                        sure!
                          @otca
                          • O
                            r trigger mode is 0
                            • O
                                @otca You are welcome.
                                This issue is a bit strange.
                                • O
                                  export WIDTH=1920
                                  export HEIGHT=1080
                                  export FPS=67
                                  • O
                                    @otca Solved:
                                    • V
                                      vitob last edited by
                                      • V
                                          veye_xumm @vitob last edited by
                                          @vitob
