    21795
    • O
      Otca @Otca last edited by
      • O
        Dmesg Logs
        Dmesg_01.txt
        v4l2-ctl --list-formats-ext
        ioctl: VIDIOC_ENUM_FMT
        	Type: Video Capture
        	[0]: 'GREY' (8-bit Greyscale)
        		Size: Discrete 1920x1080
          @otca
          export WIDTH=2432
          export HEIGHT=2056
          export FPS=28
          v4l2-ctl --set-ctrl roi_x=0
          v4l2-ctl --set-ctrl roi_y=0
          • O
            @veye_xumm Hi,
            this is the results:
            export WIDTH=2432
            export HEIGHT=2056
            export FPS=28
            Dmesg log:
            ####Dmesg of Last Line:
            Full Dmesg log:
            Dmesg.txt
              • O
                sure!
                  @otca
                  • O
                    r trigger mode is 0
                    • O
                        @otca You are welcome.
                        This issue is a bit strange.
                        • O
                          export WIDTH=1920
                          export HEIGHT=1080
                          export FPS=67
                          • O
                            @otca Solved:
                            • V
                              vitob last edited by
                              • V
                                  veye_xumm @vitob last edited by
                                  @vitob
                                    • V
                                      vitob @veye_xumm last edited by vitob
                                      nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 0
                                      model 0 not recognized
                                      nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 1
                                      nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 1
                                      NOT SUPPORTED!
                                      nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 0
                                      NOT SUPPORTED!
                                      • V
                                        @veye_xumm , let me confirm this, although I used sdkmanager to flash the board with nvidia native packages w/o issues.
                                        • V
                                          vitob @vitob last edited by
                                          @vitob said in NVidia Jetson Jetpack 6 support?:
                                          In the meantime, can you help explain this question on tegra-camera.ko and v4l2-core/*.ko? Why they needs to be updated and where can I find the source code of them? Once updating them using the veye release .ko, will that affect other cameras (for example, I want to port/develop driver for another sensor myself)? Thanks.
                                            @vitob
                                            Please use -b 9 or -b 10 as an argument.
                                            For i2c bus number, please refer to this link above.
