    21780
      @otca
      export WIDTH=2432
      export HEIGHT=2056
      export FPS=28
      v4l2-ctl --set-ctrl roi_x=0
      v4l2-ctl --set-ctrl roi_y=0
      • O
        @veye_xumm Hi,
        this is the results:
        export WIDTH=2432
        export HEIGHT=2056
        export FPS=28
        Dmesg log:
        ####Dmesg of Last Line:
        Full Dmesg log:
        Dmesg.txt
          • O
            sure!
              @otca
              • O
                r trigger mode is 0
                • O
                  Otca @Otca last edited by
                    @otca You are welcome.
                    This issue is a bit strange.
                    • O
                      export WIDTH=1920
                      export HEIGHT=1080
                      export FPS=67
                      • O
                        @otca Solved:
                        • V
                          vitob last edited by
                          • V
                              veye_xumm @vitob last edited by
                              @vitob
                                • V
                                  vitob @veye_xumm last edited by vitob
                                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 0
                                  model 0 not recognized
                                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 1
                                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 1
                                  NOT SUPPORTED!
                                  nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 0
                                  NOT SUPPORTED!
                                  • V
                                    @veye_xumm , let me confirm this, although I used sdkmanager to flash the board with nvidia native packages w/o issues.
                                    • V
                                      vitob @vitob last edited by
                                      @vitob said in NVidia Jetson Jetpack 6 support?:
                                      In the meantime, can you help explain this question on tegra-camera.ko and v4l2-core/*.ko? Why they needs to be updated and where can I find the source code of them? Once updating them using the veye release .ko, will that affect other cameras (for example, I want to port/develop driver for another sensor myself)? Thanks.
                                        @vitob
                                        Please use -b 9 or -b 10 as an argument.
                                        For i2c bus number, please refer to this link above.
                                          These driver changes add support for RAW8 RAW10 RAW12 data types on the one hand, and externally triggered modes on the other.
                                          Their code reference:
                                          https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/kernel_patch_4_mv/l4t-r36.3
                                          Compile step by step reference::
                                          https://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson
                                          1 Reply Last reply Reply Quote 1
