    21792
      @otca You are welcome.
      This issue is a bit strange.
      • O
        export WIDTH=1920
        export HEIGHT=1080
        export FPS=67
        • O
          Otca @Otca last edited by
          @otca Solved:
          • V
            vitob last edited by
            • V
                veye_xumm @vitob last edited by
                @vitob
                  • V
                    vitob @veye_xumm last edited by vitob
                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 0
                    model 0 not recognized
                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c.sh -r -f model -b 1
                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 1
                    NOT SUPPORTED!
                    nvidia@ubuntu:/work/git_repo/nvidia_jetson_veye_bsp/mv_tools_jetson/i2c_tools$ ./mv_mipi_i2c_new.sh -r -f model -b 0
                    NOT SUPPORTED!
                    • V
                      @veye_xumm , let me confirm this, although I used sdkmanager to flash the board with nvidia native packages w/o issues.
                      • V
                        vitob @vitob last edited by
                        @vitob said in NVidia Jetson Jetpack 6 support?:
                        In the meantime, can you help explain this question on tegra-camera.ko and v4l2-core/*.ko? Why they needs to be updated and where can I find the source code of them? Once updating them using the veye release .ko, will that affect other cameras (for example, I want to port/develop driver for another sensor myself)? Thanks.
                          @vitob
                          Please use -b 9 or -b 10 as an argument.
                          For i2c bus number, please refer to this link above.
                            These driver changes add support for RAW8 RAW10 RAW12 data types on the one hand, and externally triggered modes on the other.
                            Their code reference:
                            https://github.com/veyeimaging/nvidia_jetson_veye_bsp/tree/master/kernel_patch_4_mv/l4t-r36.3
                            Compile step by step reference::
                            https://wiki.veye.cc/index.php/VEYE_CS_Camera_source_for_Jetson
                            1 Reply Last reply Reply Quote 1
