    14971
    • O
      thanks for your guidance.
      The dmesg log is appended.
      MV-MIPI-IMX264.txt
        • O
          Thanks alot
            @otca
            • O
              here is dmesg log.
              sudo dmesg| grep -i 'mvcam'
              Full DMESG Log:
              IMX264.OrinNX.txt
              i2cdetect -y -r 10
              70: -- -- -- -- -- -- -- --
              VLC:
              vlc
              Opening in BLOCKING MODE
              DTB :
              TIMEOUT 30
              DEFAULT imx264
              MENU TITLE L4T boot options
              LABEL primary
                    MENU LABEL primary kernel
                    LINUX /boot/Image
                    INITRD /boot/initrd
              LABEL imx264
                    LINUX /boot/Image
                    INITRD /boot/initrd
              ls /sys/bus/i2c/drivers/
              O veye_xumm 2 Replies Last reply Reply Quote 0
              • O
                Otca @Otca last edited by
                • O
                  Dmesg Logs
                  Dmesg_01.txt
                  v4l2-ctl --list-formats-ext
                  ioctl: VIDIOC_ENUM_FMT
                  	Type: Video Capture
                  	[0]: 'GREY' (8-bit Greyscale)
                  		Size: Discrete 1920x1080
                    @otca
                    export WIDTH=2432
                    export HEIGHT=2056
                    export FPS=28
                    v4l2-ctl --set-ctrl roi_x=0
                    v4l2-ctl --set-ctrl roi_y=0
                    • O
                      @veye_xumm Hi,
                      this is the results:
                      export WIDTH=2432
                      export HEIGHT=2056
                      export FPS=28
                      Dmesg log:
                      ####Dmesg of Last Line:
                      Full Dmesg log:
                      Dmesg.txt
                        • O
                          sure!
                            @otca
                            • O
                              r trigger mode is 0
                              • O
                                  @otca You are welcome.
                                  This issue is a bit strange.
                                  • O
                                    export WIDTH=1920
                                    export HEIGHT=1080
                                    export FPS=67
                                    • O
                                      @otca Solved:
                                      • V
                                        vitob last edited by
                                        • V
                                            veye_xumm @vitob last edited by
                                            @vitob
