    SOLVED rk3588开发板接RAW-MIPI-SC132M无法获取图片
    Rockchip App camera
    mipi raw-mipi-sc132m rk3588
    6338
      veye_xumm @jihua last edited by
      @jihua
      请执行一下uname -r,把结果发上来。
      另外请检查一下你移植到的板子的mipi接口的原理图,用的哪个mipi接口,几lane的。 dts需要跟原理图对应起来才行。
      • J
        jihua @veye_xumm last edited by
        硬件接口如下:
        设备树配置如下:
         * Copyright (c) 2020 Rockchip Electronics Co., Ltd.
        	vdd_cam2_5v: vdd-cam2-5v-regulator {
        		regulator-name = "vdd_cam_5v";
        		regulator-always-on;
        		regulator-boot-on;
        		regulator-min-microvolt = <3300000>;
        		regulator-max-microvolt = <3300000>;
        	cam2_dovdd: cam2-dovdd {
        		regulator-name = "cam_dovdd";
        		regulator-boot-on;
        		regulator-min-microvolt = <1800000>;
        		regulator-max-microvolt = <1800000>;
        		vin-supply = <&vdd_cam2_5v>;
        	cam2_avdd: cam2-avdd {
        		regulator-name = "cam_avdd";
        		regulator-boot-on;
        		regulator-min-microvolt = <2800000>;
        		regulator-max-microvolt = <2800000>;
        	cam2_dvdd: cam2-dvdd {
        		regulator-name = "cam_dvdd";
        		regulator-boot-on;
        		regulator-min-microvolt = <1200000>;
        		regulator-max-microvolt = <1200000>;
        /* Link path: sensor->csi2_dphy0->mipi2_csi2->rkcif_mipi_lvds2--->rkcif_mipi_lvds2_sditf->rkisp0_vir2 */
        &i2c6 {
        	status = "okay";
        	pinctrl-names = "default";
        	pinctrl-0 = <&i2c6m3_xfer>;
            mvcam: mvcam@3b{
                   compatible = "veye,mvcam";
                   reg = <0x3b>;
                   //clocks = <&cru CLK_MIPI_CAMARAOUT_M1>;
                   //clock-names = "xvclk";
                   //pinctrl-names = "default";
                   //pinctrl-0 = <&mipim1_camera1_clk>;
                   reset-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_HIGH>;
                   pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_HIGH>;
                   port {
                            mvcam_out0: endpoint {
                                   data-lanes = <1 2>;
        &csi2_dphy0_hw {
        	status = "okay";
        &csi2_dphy0 {
        	status = "okay";
        	ports {
        		#address-cells = <1>;
        		#size-cells = <0>;
        		port@0 {
        			reg = <0>;
        			#size-cells = <0>;
        				reg = <1>;
        				remote-endpoint = <&mvcam_out0>;
        				data-lanes = <1 2>;
        		port@1 {
        			reg = <1>;
        			#size-cells = <0>;
        			csidphy0_out: endpoint@0 {
        				reg = <0>;
        &mipi2_csi2 {
        	status = "okay";
        	ports {
        		#size-cells = <0>;
        		port@0 {
        			reg = <0>;
        			#size-cells = <0>;
        				reg = <1>;
        		port@1 {
        			reg = <1>;
        			#size-cells = <0>;
        				reg = <0>;
        &rkcif {
        	status = "okay";
        &rkcif_mipi_lvds2 {
        	status = "okay";
        	port {
        		cif_mipi2_in0: endpoint {
        &rkcif_mipi_lvds2_sditf {
        	status = "disabled";
        	port {
        		mipi_lvds2_sditf: endpoint {
        &rkcif_mmu {
        	status = "okay";
        &rkisp1 {
        &isp1_mmu {
        &rkisp1_vir0 {
        	port {
        		#size-cells = <0>;
        		isp1_vir0: endpoint@0 {
        			reg = <0>;
          @jihua 按照我们之前在飞凌板子上的经验,你第一个帖子上的错误提示无关的。
          dts和原理图的对应关系的问题,你用的那个板子上有没有自带的支持的sensor?可作为参考。或者把之前系统自带的dts发个我对比看看。
          一个终端取图,另一个终端运行一下dmesg,看看报什么错误吗?
          • J
            取图时的信息和dmesg信息如下:
            下面是原来系统里的设备树,接imx415是通的:
            	ext_cam2_37m_clk: external-camera-37m-clock {
            		compatible = "fixed-clock";
            		clock-frequency = <37125000>;
            		clock-output-names = "ext_cam_37m_clk";
            		#clock-cells = <0>;
            	ext_cam2_25m_clk: external-camera-25m-clock {
            		clock-frequency = <25000000>;
            		clock-output-names = "ext_cam_25m_clk";
            		#clock-cells = <0>;
            	ext_cam2_24m_clk: external-camera-24m-clock {
            		#clock-cells = <0>;
            		clock-frequency = <24000000>;
            		clock-output-names = "ext_cam_24m_clk";
            		regulator-boot-on;
            		regulator-boot-on;
            		regulator-boot-on;
            		regulator-boot-on;
            &i2c6 {
            	status = "okay";
            	dw9714: dw9714@c {
            		status = "okay";
            		reg = <0xc>;
            		rockchip,vcm-max-current = <100>;
            		rockchip,vcm-start-current = <0>;
            		rockchip,vcm-rated-current = <100>;
            		rockchip,vcm-step-mode = <0xd>;
            		rockchip,vcm-dlc-enable = <0>;
            		rockchip,vcm-mclk = <0>;
            		rockchip,vcm-t-src = <0>;
            	ov5647: ov5647@36 {
            		compatible = "ovti,ov5647";
            		reg = <0x36>;
            		clocks = <&ext_cam2_25m_clk>;
            		clock-names = "ext_cam_25m_clk";
            		pwdn-gpios = <&gpio4 RK_PA7 GPIO_ACTIVE_LOW>;
            		lens-focus = <&dw9714>;
            		port {
            			ov5647_out: endpoint {
            				remote-endpoint = <&dphy0_in_ov5647>;
            				data-lanes = <1 2>;
            	ov5648: camera@36 {
            		compatible = "ovti,ov5648";
            		reg = <0x36>;
            		clocks = <&ext_cam2_24m_clk>;
            		dovdd-supply= <&cam2_dovdd>; /* 1.8v */
            		avdd-supply = <&cam2_avdd>;  /* 2.8v */
            		dvdd-supply = <&cam2_dvdd>;  /* 1.2v */
            		reset-gpios = <&gpio4 RK_PB2 GPIO_ACTIVE_LOW>;
            		rotation = <180>;
            		rockchip,camera-module-index = <2>;
            		rockchip,camera-module-name = "THDS11073";
            		rockchip,camera-module-lens-name = "Largan-40122a1";
            		port {
            			/* MIPI CSI-2 bus endpoint */
            			ov5648_out: endpoint {
            				remote-endpoint = <&dphy0_in_ov5648>;
            				clock-lanes = <0>;
            				data-lanes = <1 2>;
            	ov8858: ov8858@36 {
            		compatible = "ovti,ov8858";
            		reg = <0x36>;
            		rotation = <180>;
            		rockchip,camera-module-name = "HS5885-BNSM1018-V01";
            		rockchip,camera-module-lens-name = "default";
            		port {
            			ov8858_out: endpoint {
            				remote-endpoint = <&dphy0_in_ov8858>;
            				clock-lanes = <0>;
            				data-lanes = <1 2>;
            	ov13850: ov13850@10 {
            		compatible = "ovti,ov13850";
            		reg = <0x10>;
            		rotation = <180>;
            		rockchip,camera-module-name = "ZC-OV13850R2A-V1";
            		rockchip,camera-module-lens-name = "Largan-50064B31";
            		port {
            			ov13850_out: endpoint {
            				remote-endpoint = <&dphy0_in_ov13850>;
            				clock-lanes = <0>;
            				data-lanes = <1 2>;
            	imx415_2: imx415-2@1a {
            		compatible = "sony,imx415";
            		status = "okay";
            		reg = <0x1a>;
            		clocks = <&ext_cam2_37m_clk>;
            		dovdd-supply = <&cam2_dovdd>;
            		port {
            			imx415_out2: endpoint {
            				remote-endpoint = <&dphy0_in_imx415>;
            				data-lanes = <1 2 3 4>;
            &csi2_dphy0_hw {
            	status = "okay";
            &csi2_dphy0 {
            	status = "okay";
            	ports {
            		#size-cells = <0>;
            		port@0 {
            			reg = <0>;
            			#size-cells = <0>;
            			dphy0_in_ov5648: endpoint@1 {
            				reg = <1>;
            				remote-endpoint = <&ov5648_out>;
            				data-lanes = <1 2>;
            			dphy0_in_ov8858: endpoint@2 {
            				reg = <2>;
            				remote-endpoint = <&ov8858_out>;
            				data-lanes = <1 2>;
            			dphy0_in_ov13850: endpoint@3 {
            				reg = <3>;
            				remote-endpoint = <&ov13850_out>;
            				data-lanes = <1 2>;
            			dphy0_in_ov5647: endpoint@4 {
            				reg = <4>;
            				remote-endpoint = <&ov5647_out>;
            				data-lanes = <1 2>;
            			dphy0_in_imx415: endpoint@5 {
            				reg = <5>;
            				remote-endpoint = <&imx415_out2>;
            		port@1 {
            			reg = <1>;
            			#size-cells = <0>;
            				reg = <0>;
            &mipi2_csi2 {
            	status = "okay";
            	ports {
            		#size-cells = <0>;
            		port@0 {
            			reg = <0>;
            			#size-cells = <0>;
            				reg = <1>;
            		port@1 {
            			reg = <1>;
            			#size-cells = <0>;
            				reg = <0>;
            &rkcif {
            	status = "okay";
            &rkcif_mipi_lvds2 {
            	status = "okay";
            	port {
            	status = "okay";
            	port {
            &rkcif_mmu {
            	status = "okay";
            &rkisp1 {
            	status = "okay";
            &isp1_mmu {
            	status = "okay";
            &rkisp1_vir0 {
            	status = "okay";
            	port {
            		#size-cells = <0>;
            			reg = <0>;
              veye_xumm @jihua last edited by veye_xumm
              @jihua dts这么看,看不出啥问题。
              你是不是有一个转接板,这个板子原理应该没问题的吧?
              另外你现在接我们sc132,启动之后
              dmesg | grep mvcam
              dmesg | grep rkcif
              发给我看一下
              • J
                执行指令结果如下:
                硬件是有转接板的,量过了线序是对应的上的:
                e879d659-7b46-4beb-96cd-039196f1506c-e764d81e-9d1c-4ba5-b1ca-151e0dcfba18.jpg [图片]
                  @jihua
                  1处排线插歪了。
                  2处的排线没有用处建议去掉,保证mipi信号的质量。
                  • J
                    读取相机的datarate返回是-1代表什么意思。
                      @jihua 应该是这个版本的固件还没有支持这个寄存器。不影响正常出图和对接的。
                      • J
                        内核打印的信息显示datarate是1.5G,用示波器测量不到时钟波形,只能测到数据波形,这个模块的实际datarate是多少的?现在抓图的时候,内核驱动报crc错误,怀疑是排线太长或者datarate对不上。
                          @jihua
                          按照1.5G配置是没问题的,我们在多个rk3588上面都调通的。
                          你用的排线是多长的?可否拍个照片我看看。
                          • J
                            排线长度有26厘米长
                            d573eebf-ed60-4955-872c-b7609ef8ecc0-ad04fd8f-6c28-4da6-a785-2304d7f0e416.jpg [图片]
                              @jihua 线长也没有很夸张。你测测摄像头这端,入口地方的3.3V供电,实际电压是多少?
                              • J
                                VCC3V3 测量到是3.3V,MIPI_CK_N 时钟是固定的吗?时钟是多少的?设置帧率后这个时钟会变吗?
                                  @jihua 相机是固定的1188M,3588那头设置为1500M是没问题的。
                                  你把现在报的错发给我看看。
                                  • J
                                    获取一张图片报错
                                      @jihua 我们在rk平台没有遇到过这个问题。看ecc2这个错误提示的话,像是mipi信号劣化了。
