    UNSOLVED Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    Raspberry Pi App Software
    728
      veye_xumm @jambojettt last edited by
      • J
        jambojettt @veye_xumm last edited by
        @veye_xumm yes, it updated to 6.12.57, but this problem also was in 6.12.47 that it was updated from.
        How do I get the headers?
          @jambojettt said in Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+:
          My Raspberry Pi comes with headers by default. You might want to reinstall piOS? We've already released the 6.12.47 ko file on GitHub.
          • J
            • J
              jambojettt @jambojettt last edited by
              Kernel headers are installed.
              • J
                  @jambojettt
                  uname -a
                  ls /usr/lib/modules/
                  • J
                      @jambojettt
                      Sorry for reply late.
                      • J
                        make
                        reinstalled by github
                        Which one do I use?
