    USB camera
    20659
    • C
      提供一些線索...這是 /var/log/syslog 的一些資訊
      [ 4961.933476] usb 1-2.4: USB disconnect, device number 12
      [ 4970.882438] usb 1-2.4: new high-speed USB device number 13 using tegra-xusb
      [ 4970.903606] usb 1-2.4: New USB device found, idVendor=12d1, idProduct=4321
      [ 4970.903614] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 4970.903617] usb 1-2.4: Product: CS-USB-IMX307
      [ 4970.903621] usb 1-2.4: Manufacturer: Tianjin Zhonganyijia
      [ 4970.903624] usb 1-2.4: SerialNumber: 2021-04-29-v1.5
      [ 4970.905040] uvcvideo: Found UVC 1.10 device CS-USB-IMX307 (12d1:4321)
      [ 4970.905982] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
      [ 4970.917193] uvcvideo 1-2.4:1.0: Entity type for entity Extension 10 was not initialized!
      [ 4970.925351] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
      [ 4970.933539] input: CS-USB-IMX307 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input11
      [ 4970.979741] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4970.987867] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4970.996011] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.004088] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.012257] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.020492] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.028706] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.036895] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.045066] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.053206] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.061446] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.069795] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.078037] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.086199] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.094521] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.102697] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 4971.110911] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.260231] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.268496] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.276995] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.285387] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.293860] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.302262] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.310654] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.319020] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 4971.327543] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.335948] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.344292] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.352674] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.361012] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.369406] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.377790] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.386318] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.394660] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.403045] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 4971.411374] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 4971.419670] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 4971.427938] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 4971.436250] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 4971.444499] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 4971.452928] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 5018.765475] usb 1-2.4: USB disconnect, device number 13
      [ 5019.050465] usb 1-2.4: new high-speed USB device number 14 using tegra-xusb
      [ 5019.071859] usb 1-2.4: New USB device found, idVendor=12d1, idProduct=4321
      [ 5019.071865] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 5019.071869] usb 1-2.4: Product: CS-USB-IMX307
      [ 5019.071872] usb 1-2.4: Manufacturer: Tianjin Zhonganyijia
      [ 5019.071875] usb 1-2.4: SerialNumber: 2021-04-29-v1.5
      [ 5019.074779] uvcvideo: Found UVC 1.10 device CS-USB-IMX307 (12d1:4321)
      [ 5019.075927] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
      [ 5019.084098] uvcvideo 1-2.4:1.0: Entity type for entity Extension 10 was not initialized!
      [ 5019.092210] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
      [ 5019.100251] input: CS-USB-IMX307 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input12
      [ 5019.144960] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.153091] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.161241] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.169387] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.177587] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.185759] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.194705] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.202921] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.211077] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.219321] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.352440] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.360757] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.369166] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.377529] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.385906] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.394391] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5019.402716] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.411089] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.419444] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.427776] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.436038] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.444389] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.452627] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.460955] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.469267] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5019.477825] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.486160] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.494606] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.502981] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.511349] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.519751] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.528160] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.537713] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.546059] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.554462] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5019.562788] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 5019.571129] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 5019.579431] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 5019.587747] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 5019.596009] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 5019.604306] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 5078.146409] uvcvideo: Failed to set UVC probe control : -71 (exp. 34).
      [ 5078.157496] usb 1-2.4: USB disconnect, device number 14
      [ 5078.446407] usb 1-2.4: new high-speed USB device number 15 using tegra-xusb
      [ 5078.467800] usb 1-2.4: New USB device found, idVendor=12d1, idProduct=4321
      [ 5078.467806] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 5078.467809] usb 1-2.4: Product: CS-USB-IMX307
      [ 5078.467813] usb 1-2.4: Manufacturer: Tianjin Zhonganyijia
      [ 5078.467816] usb 1-2.4: SerialNumber: 2021-04-29-v1.5
      [ 5078.470465] uvcvideo: Found UVC 1.10 device CS-USB-IMX307 (12d1:4321)
      [ 5078.471587] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
      [ 5078.479723] uvcvideo 1-2.4:1.0: Entity type for entity Extension 10 was not initialized!
      [ 5078.487840] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
      [ 5078.495916] input: CS-USB-IMX307 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input13
      [ 5078.542905] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.551162] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.559371] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.567559] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.575761] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.584017] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.592309] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.600554] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.608770] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.617072] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.625240] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.633379] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.770479] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.778644] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.787072] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.795848] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 5078.804199] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.812503] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.820840] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.829081] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.837376] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.845630] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.853925] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.862165] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.870514] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 5078.879054] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.887437] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.895810] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.904180] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.912498] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.920895] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.929288] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.937663] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.946001] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.954489] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 5078.962813] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 5078.971128] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 5078.979399] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 5078.987747] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 5078.996002] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 5079.004317] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 6088.358117] uvcvideo: Failed to resubmit video URB (-1).
      [ 6653.807693] uvcvideo: Failed to set UVC probe control : -71 (exp. 34).
      [ 6653.837631] usb 1-2.4: USB disconnect, device number 15
      [ 6662.787047] usb 1-2.4: new high-speed USB device number 16 using tegra-xusb
      [ 6662.808375] usb 1-2.4: New USB device found, idVendor=12d1, idProduct=4321
      [ 6662.808382] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 6662.808385] usb 1-2.4: Product: CS-USB-IMX307
      [ 6662.808389] usb 1-2.4: Manufacturer: Tianjin Zhonganyijia
      [ 6662.808392] usb 1-2.4: SerialNumber: 2021-04-29-v1.5
      [ 6662.809783] uvcvideo: Found UVC 1.10 device CS-USB-IMX307 (12d1:4321)
      [ 6662.810743] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
      [ 6662.821950] uvcvideo 1-2.4:1.0: Entity type for entity Extension 10 was not initialized!
      [ 6662.830122] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
      [ 6662.838278] input: CS-USB-IMX307 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input14
      [ 6662.885275] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.893367] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.901637] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.909836] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.918044] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.926446] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.934702] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.942881] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.951132] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.959303] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6662.967467] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6663.115351] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6663.123726] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6663.131948] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6663.140270] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6663.148620] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 6663.156904] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.165085] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.173327] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.181513] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.189676] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.197823] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.206008] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.214132] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.222335] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 6663.230681] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.238945] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.247174] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.255483] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.263777] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.272081] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.280342] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.288592] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.296788] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.305055] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 6663.313251] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 6663.321453] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 6663.329581] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 6663.337809] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 6663.346102] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 6663.354333] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 7342.477650] usb 1-2.4: USB disconnect, device number 16
      [ 7342.844167] usb 1-2.4: new high-speed USB device number 17 using tegra-xusb
      [ 7342.865519] usb 1-2.4: New USB device found, idVendor=12d1, idProduct=4321
      [ 7342.865525] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 7342.865528] usb 1-2.4: Product: CS-USB-IMX307
      [ 7342.865532] usb 1-2.4: Manufacturer: Tianjin Zhonganyijia
      [ 7342.865535] usb 1-2.4: SerialNumber: 2021-04-29-v1.5
      [ 7342.866898] uvcvideo: Found UVC 1.10 device CS-USB-IMX307 (12d1:4321)
      [ 7342.867828] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
      [ 7342.879045] uvcvideo 1-2.4:1.0: Entity type for entity Extension 10 was not initialized!
      [ 7342.887191] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
      [ 7342.895228] input: CS-USB-IMX307 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input15
      [ 7342.939501] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7342.947675] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7342.955795] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7342.963880] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7342.972045] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7342.981108] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7342.989412] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7342.997634] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.005864] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.014096] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.022235] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.030360] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.162439] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.170627] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.179022] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.187333] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7343.195549] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.203782] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.211991] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.220211] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.228434] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.236689] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.244938] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.253222] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.261516] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7343.270060] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.278414] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.286810] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.295181] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.303548] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.311882] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.320300] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.328629] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.337016] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.345382] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7343.353774] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 7343.362036] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 7343.370356] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 7343.378604] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 7343.386896] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 7343.395186] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 7753.613657] usb 1-2.4: USB disconnect, device number 17
      [ 7753.906891] usb 1-2.4: new high-speed USB device number 18 using tegra-xusb
      [ 7753.928150] usb 1-2.4: New USB device found, idVendor=12d1, idProduct=4321
      [ 7753.928156] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
      [ 7753.928159] usb 1-2.4: Product: CS-USB-IMX307
      [ 7753.928163] usb 1-2.4: Manufacturer: Tianjin Zhonganyijia
      [ 7753.928166] usb 1-2.4: SerialNumber: 2021-04-29-v1.5
      [ 7753.929585] uvcvideo: Found UVC 1.10 device CS-USB-IMX307 (12d1:4321)
      [ 7753.930559] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
      [ 7753.939037] uvcvideo 1-2.4:1.0: Entity type for entity Extension 10 was not initialized!
      [ 7753.947168] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
      [ 7753.955321] input: CS-USB-IMX307 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input16
      [ 7754.002503] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.010592] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.018985] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.027163] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.035381] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.043617] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.054862] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.063064] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.071327] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.079595] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.212479] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.220778] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.229277] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.237661] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.246054] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.254522] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 7754.262867] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.271184] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.279469] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.287775] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.296068] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.304370] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.312554] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.320775] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.328988] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
      [ 7754.337448] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.345632] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.353887] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.362624] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.371018] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.379358] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.387774] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.396119] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.404543] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.412884] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 7754.421265] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 7754.429508] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 7754.437820] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
      [ 7754.446090] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 7754.454384] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [ 7754.462685] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
      [21453.263169] Call trace:
      [21453.263173] [<ffffff80082f5480>] sysfs_remove_group+0x98/0xa0
      [21453.263177] [<ffffff80082f54c4>] sysfs_remove_groups+0x3c/0x58
      [21453.263180] [<ffffff800877af94>] device_remove_attrs+0x5c/0x80
      [21453.263183] [<ffffff800877bcd0>] device_del+0x108/0x248
      [21453.263187] [<ffffff8008ad0f64>] __input_unregister_device+0x134/0x158
      [21453.263190] [<ffffff8008ad1d2c>] input_unregister_device+0x5c/0x80
      [21453.263203] [<ffffff80011e092c>] uvc_status_cleanup+0x3c/0x48 [uvcvideo]
      [21453.263213] [<ffffff80011d53e8>] 0xffffff80011d53e8
      [21453.263224] [<ffffff80011d5640>] 0xffffff80011d5640
      [21453.263227] [<ffffff8008b171a8>] v4l2_device_release+0xd0/0x110
      [21453.263230] [<ffffff800877b124>] device_release+0x3c/0x98
      [21453.263234] [<ffffff800845e5cc>] kobject_put+0x94/0x1e8
      [21453.263237] [<ffffff800877b624>] put_device+0x24/0x30
      [21453.263239] [<ffffff8008b16448>] v4l2_release+0x60/0xa0
      [21453.263243] [<ffffff800825e7f8>] __fput+0x90/0x1d0
      [21453.263247] [<ffffff800825e9b0>] ____fput+0x20/0x30
      [21453.263252] [<ffffff80080d8d84>] task_work_run+0xbc/0xd8
      [21453.263256] [<ffffff800808b2ec>] do_notify_resume+0xa4/0xb0
      [21453.263259] [<ffffff800808379c>] work_pending+0x8/0x10
      • C
        希望有改版時,對於 uvcvideo 的參數也能夠支援。目前我無法對 power_line_frequency 做設定,對於不支援這些參數這點我非常困擾。以下是對 CS-USB-IMX307 (/dev/video0) 以及另一款 USB Camera module (/dev/video1) 的比較
        v4l2-ctl -d /dev/video0 -list-ctrls
        VIDIOC_S_INPUT: failed: Device or resource busy
        aaeon@aaeon2-desktop:~$ v4l2-ctl -d /dev/video1 -list-ctrls
        Video input set to 0 (Camera 1: Camera, ok)
        power_line_frequency 0x00980918 (menu) : min=0 max=2 default=1 value=1
          @coolmitch
          这个问题,可能是v4l2-ctl在一个一个查询参数配置的时候,遇到不支持的参数之后就停掉了。实际摄像头是支持power_line_frequency 的,要不然我们用pc的软件也会显示不支持。
          当然怎样通过命令行去配置,我现在只能想到C语言调用v4l2接口一途。
          • C
            @veye_xumm 一般是可以這樣設定
            v4l2-ctl -d /dev/video1 --set-ctrl=power_line_frequency=2
            不會報錯誤訊息
            但我對 CS-USB-IMX307 設定時,回應是
            v4l2-ctl -d /dev/video0 --set-ctrl=power_line_frequency=2
            unknown control 'power_line_frequency'
            對了,我去下載你說那個 potplayer 但畫面長不一樣,是不是版本不同?我找不到設定的地方....
              @coolmitch
              可以参考一下这篇文章:
              http://wiki.veye.cc/index.php/Windows系统下怎样查看USB摄像头视频
              另外,我这边对opencv和python不太熟。使用你给的ffmpeg的方法,的确重现了一次问题。
              现在我的结论是,并不是内存泄漏,需要进一步查找,困难度比预期的要高。
              有没有更快重现问题的方法?
              • C
                我用 ffmpeg 看到的錯誤訊息跟 python3+opencv 跑出來的有點不太一樣。但都需要跑很久(每次都大概需要 2~3hrs 左右)可以重現。(本來每分鐘跑一個循環需要 2 天半)。如果我給你 python3 的程式碼,你那邊能夠執行嗎?(需要有 opencv 安裝好)
                  @coolmitch
                  我今天安装了一个3.2.0版本的opencv,跑你之前给的例程不行。
                  安装4.5.2的版本,失败了。
                  • C
                    我重寫一個 python3 程式給你。照理沒有一定要 4.5.2,但你可以試看看 https://qengineering.eu/install-opencv-4.5-on-jetson-nano.html
                    我是照這個步驟編譯的。編譯過程一定要把 swap 打開,不然虛擬記憶體會不夠用。
                      @coolmitch
                      我也是按照这个步骤做的。但是cmake阶段报错了。😰
                      • C
                        @veye_xumm cmake 可能需要重新安裝新版。
                        參考這個(我有點忘記更新 cmake 的程序了)
                        https://stackoverflow.com/questions/49859457/how-to-reinstall-the-latest-cmake-version
                        ----------------- BEGIN imx307_debug.py --------------------
                        import cv2
                        def run_once():
                        cap = cv2.VideoCapture('/dev/video0', cv2.CAP_V4L)
                        # cap.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter.fourcc('M','J','P','G'))
                        cap.set(cv2.CAP_PROP_FOURCC, cv2.VideoWriter.fourcc('h','2','6','4'))
                        cap.set(cv2.CAP_PROP_FRAME_WIDTH, 1920)
                        cap.set(cv2.CAP_PROP_FRAME_HEIGHT, 1080)
                        cap.set(cv2.CAP_PROP_FPS, 30)
                        # 讀取 10 個 frames
                        for i in range(10):
                            ret, frame = cap.read()
                        cap.release()
                        def main():
                        cap_count = 0
                        while True:
                        run_once()
                        print('-- %d --' % cap_count)
                        cap_count += 1
                        if name == 'main':
                        main()
                        ----------------- END imx307_debug.py --------------------
                        • C
                          重新把程式碼排版ㄧ下...
                          #! /usr/bin/python3
                          import cv2
                          def run_once():
                              # 讀取 10 個 frames
                              for i in range(10):
                              cap.release()
                          def main():
                              cap_count = 0
                              while True:
                                  run_once()
                                  cap_count += 1
                          if __name__ == '__main__':
                              main()
                            @coolmitch
                            请问你的cmake版本是?
                            我的是3.10.2
                              @coolmitch
                              我更新了一下cmake,还是编译不过。
                              anyway,这事先放一放。
                              我现在改了一个版本的固件,用ffmpeg循环测试的方法,测试到6000+次数,还是稳定的。
                              请你也升级并老化测试一下:
                              下载链接:
                              https://www.mediafire.com/file/nnysng0map7jnf0/dimaging_upgrade.bin/file
                              升级方法:
                              http://wiki.veye.cc/index.php/USB升级固件方法
                              • C
                                cmake --version
                                cmake version 3.10.2
                                CMake suite maintained and supported by Kitware (kitware.com/cmake).
                                我的也是 3.10.2
                                所以會不會是有什麼 dependent lib 沒有安裝完全?
                                • C
                                  升級後,開機看到這個
                                  [ 48.421580] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                                  [ 53.659534] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                                  [ 53.672858] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                                  [ 53.681295] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                                  [ 89.889940] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                                  [ 410.317273] uvcvideo: Failed to resubmit video URB (-1).
                                  不過我還是讓他去跑著測試了...
                                  今晚先用 python3 的程式跑跑看...
                                    @coolmitch
                                    我这边老化一夜,已经运行38000+次数,现在还是稳定的。 期待你的结果。
                                    • C
                                      @veye_xumm 我昨晚也跑了 22000+ 次,這樣應該就過了。所以是什麼原因造成的?
                                        @coolmitch
                                        应该是我这边程序在处理close的时候,对资源的释放上有逻辑不完善的地方。 希望你后面也继续测试观察吧。嵌入式端控制frequency的问题,我再研究一下。
                                        • C
                                            @coolmitch
