    SOLVED Camera sync mode
    FPD LINK III Camera
    15902
      veye_xumm @g-towboat last edited by
      @g-towboat
      Please refer to:
      http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
      • G
        g-towboat @veye_xumm last edited by
        @veye_xumm I still have blue Images.
        Wire configuration standard.
        Changed as reference in http://forum.veye.cc/topic/22/i-want-to-synchronize-the-two-cameras-in-sync-mode/6?_=1616485571342
        Can you please check what i am doing wrong or post a detailed photo of the right configuration.
        Thank you
          @g-towboat
          I think you pick out the wrong wire.
          • G
            SYNC signal connect:
            J7-3 (GPIO0) to J1-3 (GPIO0),
            J7-2 (GND) to J1-2 (GND)
            Any other wiring to do?
              everyone
              no
              • G
                Any other ideas whats wrong ?
                  @g-towboat
                  • G
                    @veye_xumm Hi Xumm,
                    #!/bin/bash
                    SYNC_INIT="sync_init"
                    STREAM_MODE="streammode"
                    echo -e "connected cameras:"
                    ls -l /dev/video*
                    This is the result:
                    connected cameras:
                    w stream mode master
                    w stream mode slave
                    w stream mode slave
                    w stream mode slave
                    w stream mode slave
                    w stream mode slave
                    w stream mode slave
                    w stream mode slave
                    Looks good for me.
                    Camera 0_1
                    Camera 0_2
                    Camera 1_1
                    Camera 1_2
                    Camera 2_1
                    Camera 2_2
                    Camera 3_1
                    Camera 3_2
                    #!/bin/bash
                    cameras=7
                    counter=0
                    do
                    	echo -e "Camera_"$counter
                    	((counter++))
                    done
                    Camera 1 images looks good.
                      veye_xumm @g-towboat last edited by veye_xumm
                      @g-towboat
                      • G
                        Hi here is my drawing:
                        Red: the jumpers
                        Camera 1 /dev/video0 image ok
                        Camera 4 /dev/video3 image ok
                          @g-towboat
                          • G
                            Here is an image
                              @g-towboat
                              • G
                                  @g-towboat
                                  • G
                                    • G
                                      veye_xumm 1 Reply Last reply Reply Quote 1
                                        @g-towboat
                                        It works fine here.
                                        Sorry again.
                                        • G
                                            @g-towboat
                                            It is really nice.
                                            ./fpdlink3_i2c_jetson.sh -f sync_init .....
                                            This cmd need to set after each reboot.
                                            ./cs_mipi_i2c.sh -w -f streammode
                                            The camera can save streammode.
