    SOLVED Camera sync mode
    FPD LINK III Camera
    15915
    • G
      g-towboat @veye_xumm last edited by
      @veye_xumm Hi Xumm,
      #!/bin/bash
      SYNC_INIT="sync_init"
      STREAM_MODE="streammode"
      echo -e "connected cameras:"
      ls -l /dev/video*
      This is the result:
      connected cameras:
      w stream mode master
      w stream mode slave
      w stream mode slave
      w stream mode slave
      w stream mode slave
      w stream mode slave
      w stream mode slave
      w stream mode slave
      Looks good for me.
      Camera 0_1
      Camera 0_2
      Camera 1_1
      Camera 1_2
      Camera 2_1
      Camera 2_2
      Camera 3_1
      Camera 3_2
      #!/bin/bash
      cameras=7
      counter=0
      do
      	echo -e "Camera_"$counter
      	((counter++))
      done
      Camera 1 images looks good.
        veye_xumm @g-towboat last edited by veye_xumm
        @g-towboat
        • G
          Hi here is my drawing:
          Red: the jumpers
          Camera 1 /dev/video0 image ok
          Camera 4 /dev/video3 image ok
            @g-towboat
            • G
              Here is an image
                @g-towboat
                • G
                    @g-towboat
                    • G
                      • G
                        veye_xumm 1 Reply Last reply Reply Quote 1
                          @g-towboat
                          It works fine here.
                          Sorry again.
                          • G
                              @g-towboat
                              It is really nice.
                              ./fpdlink3_i2c_jetson.sh -f sync_init .....
                              This cmd need to set after each reboot.
                              ./cs_mipi_i2c.sh -w -f streammode
                              The camera can save streammode.
