    SOLVED Camera sync mode
    FPD LINK III Camera
    15902
      veye_xumm @g-towboat last edited by
      @g-towboat
      • G
        g-towboat @veye_xumm last edited by
        @veye_xumm Hi Xumm,
        #!/bin/bash
        SYNC_INIT="sync_init"
        STREAM_MODE="streammode"
        echo -e "connected cameras:"
        ls -l /dev/video*
        This is the result:
        connected cameras:
        w stream mode master
        w stream mode slave
        w stream mode slave
        w stream mode slave
        w stream mode slave
        w stream mode slave
        w stream mode slave
        w stream mode slave
        Looks good for me.
        Camera 0_1
        Camera 0_2
        Camera 1_1
        Camera 1_2
        Camera 2_1
        Camera 2_2
        Camera 3_1
        Camera 3_2
        #!/bin/bash
        cameras=7
        counter=0
        do
        	echo -e "Camera_"$counter
        	((counter++))
        done
        Camera 1 images looks good.
          veye_xumm @g-towboat last edited by veye_xumm
          @g-towboat
          • G
            Hi here is my drawing:
            Red: the jumpers
            Camera 1 /dev/video0 image ok
            Camera 4 /dev/video3 image ok
              @g-towboat
              • G
                Here is an image
                  @g-towboat
                  • G
                      @g-towboat
                      • G
                        • G
                          veye_xumm 1 Reply Last reply Reply Quote 1
                            @g-towboat
                            It works fine here.
                            Sorry again.
                            • G
                                @g-towboat
                                It is really nice.
                                ./fpdlink3_i2c_jetson.sh -f sync_init .....
                                This cmd need to set after each reboot.
                                ./cs_mipi_i2c.sh -w -f streammode
                                The camera can save streammode.
