    SOLVED CS-FPD-CAM-IMX327摄像头树莓派驱动模式连接不成功
    11082
      veye_xumm @刚子 last edited by
      @刚子 你这个系统版本还是很老。
      给你们做的这个fpdlink的驱动版本是6.1.21-v7l+
      release\driver_bin\6.1.21-v7l+ 目录中可以看到。
      • 刚
        刚子 @veye_xumm last edited by
        @veye_xumm 那我下载最新版本了
        Raspberry Pi OS with desktop
        Release date: May 3rd 2023
        System: 32-bit
        Kernel version: 6.1
        Debian version: 11 (bullseye)
        Show SHA256 file integrity hash:
        • 刚
          刚子 @刚子 last edited by
          @刚子 当前只有在6.1.21-v7l+ 中有ds90ub954 文件,别的版本都没有,当前我们系统已经安装成6.1.21-v8+了,请帮忙生成该版本的文件
            @刚子 https://wiki.veye.cc/index.php/Build_drivers_from_source_for_rpi/zh
            请按照这个步骤编译一下即可。
            • 刚
              你好,我们买的是免插排线的板子,现在不插排线图像出不来,怎么处理呢用的是这种方式就接入的:
              https://wiki.veye.cc/index.php/CS-MIPI-X_for_Raspberry_Pi/zh#.E7.A1.AC.E4.BB.B6.E5.87.86.E5.A4.87.E5.8F.8A.E5.AE.89.E8.A3.85
                • 刚
                    这两个板子拆开,拍照我看看
                    • 刚
                        • 刚
                            @刚子 你不是要用驱动模式吗?
                            参考这个文章。
                            • 刚
                                @刚子 驱动模式下,执行下面几个命令给我看看
                                tail /boot/config.txt
                                cat /etc/rc.local
                                dmesg | veye grep
                                dmesg | veye 954
                                • 刚
                                    @刚子 不好意思,刚才两个命令写错了
                                    dmesg | grep veye
                                    dmesg | grep 954
                                    • 刚
                                      @veye_xumm lingchuang@raspberrypi:~ $ tail /boot/config.txt
                                      Run as fast as firmware / board allows
                                      arm_boost=1
                                      [all]
                                      gpu_mem=128
                                      dtparam=i2c_vc=on
                                      arm_64bit=0
                                      dtoverlay=ds90ub954
                                      gpu_mem=256
                                      #dtoverlay=veyecam2m
                                      lingchuang@raspberrypi:~ $ cat /etc//rc.local
                                      #!/bin/sh -e
                                      rc.local
                                      This script is executed at the end of each multiuser runlevel.
                                      Make sure that the script will "exit 0" on success or any other
                                      value on error.
                                      In order to enable or disable this script just change the execution
                                      bits.
                                      By default this script does nothing.
                                      Print the IP address
                                      _IP=$(hostname -I) || true
                                      if [ "$_IP" ]; then
                                      printf "My IP address is %s\n" "$_IP"
                                      fi
                                      sleep 1;sudo dtcoverlay veyecam2m
                                      exit 0
                                      lingchuang@raspberrypi:~ $ dmesg |grep veye
                                      lingchuang@raspberrypi:~ $ dmesg |grep 954
                                      [ 5.895480] systemd[1]: Listening on udev Control Socket.
                                      [ 11.120745] ds90ub954: loading out-of-tree module taints kernel.
                                      [ 11.122072] i2c-ds90ub954 10-0030: ds90ub954_probe: start
                                      [ 11.122091] i2c-ds90ub954 10-0030: ds90ub954_parse_dt: deserializer:
                                      [ 11.122116] i2c-ds90ub954 10-0030: pass-gpio not found, ignoring
                                      [ 11.122244] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: parsing serializers device tree:
                                      [ 11.122267] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio0-output-enable property not found
                                      [ 11.122279] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio0-output-enable to default val: 0
                                      [ 11.122291] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio1-output-enable property not found
                                      [ 11.122303] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio1-output-enable to default val: 0
                                      [ 11.122315] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio2-output-enable property not found
                                      [ 11.122327] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio2-output-enable to default val: 0
                                      [ 11.122339] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio3-output-enable property not found
                                      [ 11.122351] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio3-output-enable to default val: 0
                                      [ 11.122363] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio0-control property not found
                                      [ 11.122374] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio0-control to default val: 0b1000
                                      [ 11.122386] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio1-control property not found
                                      [ 11.122397] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio1-control to default val: 0b1000
                                      [ 11.122409] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio2-control property not found
                                      [ 11.122420] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio2-control to default val: 0b1000
                                      [ 11.122433] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - gpio3-control property not found
                                      [ 11.122443] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: gpio3-control to default val: 0b1000
                                      [ 11.122456] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - hs-clk-div property not found
                                      [ 11.122467] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - hs-clk-div set to default val: 0x2 (div by 4)
                                      [ 11.122480] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - div-m-val property not found
                                      [ 11.122491] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - div-m-val set to default val: 1
                                      [ 11.122503] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - div-n-val property not found
                                      [ 11.122514] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - div-n-val set to default val: 0x28
                                      [ 11.122653] i2c-ds90ub954 10-0030: ds90ub953_i2c_client init client done
                                      [ 11.122726] i2c-ds90ub954 10-0030: ds90ub953_regmap_init init regmap done
                                      [ 11.122805] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - virtual-channel-map property not found
                                      [ 11.122817] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: - virtual-channel-map set to default val: 0xE4
                                      [ 11.122828] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: serializer 0 successfully parsed
                                      [ 11.122843] i2c-ds90ub954 10-0030: ds90ub953_parse_dt: done
                                      [ 11.122854] i2c-ds90ub954 10-0030: ds90ub954_init starting
                                      [ 11.127312] i2c-ds90ub954 10-0030: ds90ub954_init: device ID: 0x60, code:_UB954, revision: 0x20
                                      [ 11.644062] i2c-ds90ub954 10-0030: ds90ub954_init: start init of serializer rx_port 0
                                      [ 12.614231] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=0 x 10ms
                                      [ 12.644197] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=1 x 10ms
                                      [ 12.674230] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=2 x 10ms
                                      [ 12.704210] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=3 x 10ms
                                      [ 12.734180] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=4 x 10ms
                                      [ 12.764177] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=5 x 10ms
                                      [ 12.794178] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=6 x 10ms
                                      [ 12.824204] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=7 x 10ms
                                      [ 12.864201] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=8 x 10ms
                                      [ 12.894663] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=9 x 10ms
                                      [ 12.924179] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=10 x 10ms
                                      [ 12.955602] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=11 x 10ms
                                      [ 12.994205] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=12 x 10ms
                                      [ 13.024258] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=13 x 10ms
                                      [ 13.054206] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=14 x 10ms
                                      [ 13.084297] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=15 x 10ms
                                      [ 13.114304] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=16 x 10ms
                                      [ 13.144178] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=17 x 10ms
                                      [ 13.174184] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=18 x 10ms
                                      [ 13.204235] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=19 x 10ms
                                      [ 13.234262] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=20 x 10ms
                                      [ 13.264236] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=21 x 10ms
                                      [ 13.294175] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=22 x 10ms
                                      [ 13.324189] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=23 x 10ms
                                      [ 13.354255] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=24 x 10ms
                                      [ 13.384248] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=25 x 10ms
                                      [ 13.414222] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=26 x 10ms
                                      [ 13.444192] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=27 x 10ms
                                      [ 13.474281] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=28 x 10ms
                                      [ 13.504223] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=29 x 10ms
                                      [ 13.534201] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=30 x 10ms
                                      [ 13.564190] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=31 x 10ms
                                      [ 13.599568] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=32 x 10ms
                                      [ 13.624208] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=33 x 10ms
                                      [ 13.664255] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=34 x 10ms
                                      [ 13.694247] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=35 x 10ms
                                      [ 13.724242] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=36 x 10ms
                                      [ 13.754211] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=37 x 10ms
                                      [ 13.784222] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=38 x 10ms
                                      [ 13.814211] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=39 x 10ms
                                      [ 13.844213] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=40 x 10ms
                                      [ 13.874203] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=41 x 10ms
                                      [ 13.904183] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=42 x 10ms
                                      [ 13.934173] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=43 x 10ms
                                      [ 13.964321] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=44 x 10ms
                                      [ 13.994200] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=45 x 10ms
                                      [ 14.024269] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=46 x 10ms
                                      [ 14.054195] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=47 x 10ms
                                      [ 14.084233] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=48 x 10ms
                                      [ 14.114172] i2c-ds90ub954 10-0030: ds90ub954_init: DEVICE STS: 0xd3, id=49 x 10ms
                                      [ 14.114194] i2c-ds90ub954 10-0030: ds90ub954_init: Backchannel setup failed!
                                      [ 14.114205] i2c-ds90ub954 10-0030: ds90ub954_init: init deserializer rx_port 0 failed
                                      [ 14.114216] i2c-ds90ub954 10-0030: ds90ub954_init: deserializer rx_port 0 is deactivated
                                      [ 14.116756] i2c-ds90ub954 10-0030: ds90ub954_probe: init ds90ub954_done
                                        @刚子
                                        有两个问题。
                                        1. /etc//rc.local中增加的这行,关键字是dtoverlay,你多写了一个c。
                                          所以现在表现的是veyecam2m驱动并没有加载上,dmesg | grep veye指令没有任何打印信息。
                                        2. 系统初始化probe fpdlink的接收模块的时候,提示报错。应该是硬件连接的问题。
                                          请检查:
                                          2.1 是否供电正确?
                                          2.2 FFC 排线是否方向正确?
                                        刚 3 Replies Last reply Reply Quote 0
                                        • 刚
                                          @veye_xumm 使用你们自带的异侧线,供电12V 直流,应该没问题,之前的方式已经连接成功。
                                          • 刚
                                            错误1 /etc//rc.local中增加的这行,关键字是dtoverlay,你多写了一个c。 已经修改
                                            显示如下
                                            [ 14.024096] veyecam2m 10-003b: probe failed
