    SOLVED IMX462M pixelformat on RPi5
    Machine Vision camera
    10424
    • A
      Hi, thank you for update.
      I'm stuck with compiling libcamera now, with same error as here : https://github.com/raspberrypi/libcamera/issues/151
      Did not find solution yet, probably need play with source code, will let you know if any updates.
        @alex_ai
        You can use the latest libpisp and try again.
        • A
          Hi, it helped but I had to use 1.0.6 tag of libpisp, with the latest version I had compile errors.
          Now for command : rpicam-hello -v
          I have this error:
          I used set media script before:
          Maybe forgot something else.
            @alex_ai ./media_setting_rpi5**.sh is not necessary.
            • A
              Hi, I noticed that version of libcamera different on my screenshot (it 0.2.0 but I installed 0.3.0)
              I uninstalled rpicam-apps and rebuild it from source code again and it uses my version of libcamera now.
              if execute rpicam-still -v I have next error:
              In commit I see added json file only to vc4 folder (for RPi4) , can we add it to pisp folder (for RPi5) it should have name : "mvcam_mono.json"? it has different format and can't use same file from vc4.
              Also I managed start video by this command:
              rpicam-still --tuning-file /source/libcamera/src/ipa/rpi/pisp/data/uncalibrated.json -t 0
              and it works!
              But better run it without additional parameters
              Thank you.
              • A
                  @alex_ai
                  • A
                    • A
                      • A
                          @alex_ai
                            @alex_ai
                            • A
                              PS:
                              veye_xumm A 2 Replies Last reply Reply Quote 0
                                veye_xumm @alex_ai last edited by veye_xumm
                                @alex_ai
                                • A
                                  Yes, version is 1.09 after upgrade
                                  • A
                                    Finally tested, for gain value 20 it is looks pretty same with color sensor with ISP, but background no so black as for color sensor.
                                    For me this issue resolved, attached examples to compare (10 seconds stacks)
                                    IMX462 mono
                                    IMX462 color with ISP
