    SOLVED IMX462M pixelformat on RPi5
    Machine Vision camera
    10424
      @alex_ai
      • A
        • A
          • A
              @alex_ai
                @alex_ai
                • A
                  PS:
                  veye_xumm A 2 Replies Last reply Reply Quote 0
                    veye_xumm @alex_ai last edited by veye_xumm
                    @alex_ai
                    • A
                      Yes, version is 1.09 after upgrade
                      • A
                        Finally tested, for gain value 20 it is looks pretty same with color sensor with ISP, but background no so black as for color sensor.
                        For me this issue resolved, attached examples to compare (10 seconds stacks)
                        IMX462 mono
                        IMX462 color with ISP
