    UNSOLVED Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+
    Raspberry Pi App Software
    1014
    • J
      jambojettt @veye_xumm last edited by
      @veye_xumm yes, it updated to 6.12.57, but this problem also was in 6.12.47 that it was updated from.
      How do I get the headers?
        veye_xumm @jambojettt last edited by
        @jambojettt said in Can't get v4l2 to work, rasbperry pi 4b, rpi os x64, 6.12.57-v8+:
        My Raspberry Pi comes with headers by default. You might want to reinstall piOS? We've already released the 6.12.47 ko file on GitHub.
        • J
          • J
            jambojettt @jambojettt last edited by
            Kernel headers are installed.
            • J
                @jambojettt
                uname -a
                ls /usr/lib/modules/
                • J
                    @jambojettt
                    Sorry for reply late.
                    • J
                      make
                      reinstalled by github
                      Which one do I use?
                        @jambojettt
