    USB camera
    20659
    • C
      升級後,開機看到這個
      [ 48.421580] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 53.659534] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 53.672858] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
      [ 53.681295] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 89.889940] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
      [ 410.317273] uvcvideo: Failed to resubmit video URB (-1).
      不過我還是讓他去跑著測試了...
      今晚先用 python3 的程式跑跑看...
        @coolmitch
        我这边老化一夜,已经运行38000+次数,现在还是稳定的。 期待你的结果。
        • C
          @veye_xumm 我昨晚也跑了 22000+ 次,這樣應該就過了。所以是什麼原因造成的?
            @coolmitch
            应该是我这边程序在处理close的时候,对资源的释放上有逻辑不完善的地方。 希望你后面也继续测试观察吧。嵌入式端控制frequency的问题,我再研究一下。
            • C
                @coolmitch
                • C
                  對了,在 CS-USB-IMX307 新版韌體更新後,插入主機時會出現以下訊息,請問那些 Failed to query (GET_DEF) UVC control ... 是否就是 driver 要去讀取 uvccamera 參數時讀不到的錯誤?
                  [66391.767449] usb 1-2.4: new high-speed USB device number 5 using tegra-xusb
                  [66391.788802] usb 1-2.4: New USB device found, idVendor=12d1, idProduct=4321
                  [66391.788807] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
                  [66391.788810] usb 1-2.4: Product: CS-USB-IMX307
                  [66391.788813] usb 1-2.4: Manufacturer: Tianjin Zhonganyijia
                  [66391.788815] usb 1-2.4: SerialNumber: 2021-04-29-v1.5
                  [66391.790104] uvcvideo: Found UVC 1.10 device CS-USB-IMX307 (12d1:4321)
                  [66391.791116] uvcvideo 1-2.4:1.0: Entity type for entity Processing 2 was not initialized!
                  [66391.799329] uvcvideo 1-2.4:1.0: Entity type for entity Extension 10 was not initialized!
                  [66391.807507] uvcvideo 1-2.4:1.0: Entity type for entity Camera 1 was not initialized!
                  [66391.815533] input: CS-USB-IMX307 as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/input/input3
                  [66391.860569] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.868750] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.876889] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.885043] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.893245] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.901418] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.909611] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.917744] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.925863] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.933954] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.942076] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.950219] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.958366] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.966488] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.974603] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.982734] uvcvideo: Failed to query (GET_DEF) UVC control 9 on unit 2: -32 (exp. 2).
                  [66391.990897] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66391.999007] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.007219] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.015352] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.023488] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.031630] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.039743] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.047865] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.056021] uvcvideo: Failed to query (GET_DEF) UVC control 4 on unit 2: -32 (exp. 2).
                  [66392.064287] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.072494] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.080699] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.088904] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.097111] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.105311] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.113525] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.121728] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.129935] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.138162] uvcvideo: Failed to query (GET_CUR) UVC control 11 on unit 2: -32 (exp. 1).
                  [66392.146380] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
                  [66392.154495] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
                  [66392.162626] uvcvideo: Failed to query (GET_DEF) UVC control 8 on unit 2: -32 (exp. 2).
                  [66392.170738] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
                  [66392.178855] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
                  [66392.186981] uvcvideo: Failed to query (GET_DEF) UVC control 1 on unit 2: -32 (exp. 2).
                    @coolmitch
                    这个就是对于uvc参数支持不完善所体现出来的。
                      @coolmitch
                      我查了一下 powerhz 这个选项,应该是UVC control 5,这个是支持的。
                      至于为何v4l2-ctl报错,暂时还不清楚。
                      • C
                        不好的消息
                        執行 29525 次之後,再度發生一樣的狀況。不過至少不是 6000 次斷。
                          @coolmitch
                          建议你暂时先设计一个机制,遇到问题时,或者定时,将jetson重启一下。
                          我觉得jetson重启的时候,usb接口会有断电重新上电的操作(需要验证),可以将系统整个从错误状态中恢复。
                          • C
                            • C
                                @coolmitch
                                你好,不知你的jetson nano是哪个版本。
                                以下帖子作为参考。
                                • C
                                    @coolmitch
                                    • C
                                      @veye_xumm 哈,這招我也早用過了,無效。
                                      • C
                                        色度是指這個嗎?我可以試看看
                                        我用 v4l2-ctl 下
                                        可是它還是顯示 value=50
                                        • C
                                          coolmitch @coolmitch last edited by
                                          v4l2-ctl -d /dev/video1 --all
                                          Driver name : uvcvideo
                                          Card type : USB Camera
                                          Driver version: 4.9.201
                                          Capabilities : 0x84200001
                                          Video Capture
                                          Streaming
                                          Extended Pix Format
                                          Device Capabilities
                                          Device Caps : 0x04200001
                                          Video Capture
                                          Streaming
                                          Extended Pix Format
                                          Priority: 2
                                          Format Video Capture:
                                          Width/Height : 1280/720
                                          Pixel Format : 'MJPG'
                                          Field : None
                                          Bytes per Line : 0
                                          Size Image : 1843200
                                          Colorspace : sRGB
                                          Flags :
                                          Pixel Aspect: 1/1
                                          Capabilities : timeperframe
                                          Read buffers : 0
                                          hue 0x00980903 (int) : min=-180 max=180 step=1 default=0 value=50
                                          Video Capture
                                          Streaming
                                          Extended Pix Format
                                          Device Capabilities
                                          Video Capture
                                          Streaming
                                          Extended Pix Format
                                          Priority: 2
                                          Field : None
                                          Bytes per Line : 0
                                          Colorspace : sRGB
                                          Flags :
                                          Pixel Aspect: 1/1
                                          Read buffers : 0
                                            @coolmitch
