    SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    3972
    • M
      maponarooo @veye_xumm last edited by maponarooo
      @veye_xumm These are Xavier NX dtbs. Which one is IMX385 dtb?
      quad@quad-nx:~/QIDS/nvidia_jetson_veye_bsp/dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb$ ls
      common CS-MIPI-SC132 VEYE-MIPI-CAM2M
      CS-MIPI-IMX307 CS-MIPI-SC132-fpdlink VEYE-MIPI-CAM2M-fpdlink
      CS-MIPI-IMX307-fpdlink MV-MIPI-CAM VEYE-MIPI-IMX335
      $ find . -name tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-SC132/tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/VEYE-MIPI-CAM2M-fpdlink/tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/VEYE-MIPI-CAM2M/tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/MV-MIPI-CAM/tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-SC132-fpdlink/tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-IMX307/tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/VEYE-MIPI-IMX335/tegra194-p3668-0000-p3509-0000.dtb
      ./dtbs/Xavier-NX/JetPack_5.0.1_DP_Linux_JETSON_XAVIER_NX_TARGETS/dts dtb/CS-MIPI-IMX307-fpdlink/tegra194-p3668-0000-p3509-0000.dtb
        @maponarooo said in IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera:
        VEYE-MIPI-CAM2M
        section 3.4
        • M
          @veye_xumm Okay. but can't play camera. What's the matter?
          4.2.3 gstreamer examples on Jetpack5.x
          New clock: GstSystemClock
          Additional debug info:
          Buffer pool activation failed
          Waiting for EOS...
          Caught SIGSEGV
          #0 0x0000ffff9b480f08 in __GI___poll
          #1 0x0000ffff9b5aeb30 in () at /lib/aarch64-linux-gnu/libglib-2.0.so.0
          #2 0x0000ffff9b5aeef0 in g_main_loop_run ()
          #3 0x0000ffff9b751ac4 in gst_bus_poll
          #4 0x0000aaaae8aa4980 in event_loop
          #5 0x0000aaaae8aa38c8 in main (argc=<optimized out>, argv=<optimized out>)
          Spinning. Please run 'gdb gst-launch-1.0 3457' to continue debugging, Ctrl-C to quit, or Ctrl-\ to dump core.
            @maponarooo
            Sorry, I have not encountered this problem, this gstreamer command works just fine in our case.
            The 5.0.1DP version is unstable and has many bugs. NVIDIA should release a stable version soon, within a day or two, as far as I know.
            You can submit the problem to nvidia's forum, but I guess they won't give a solution and will make you wait for the next version. That's what I suggested.
            • M
              @veye_xumm Oh! No.............
              I have already build my applications all on JetPack5.01DP.
              Why this is so complicate?
              I can't wait new version....
              • M
                @veye_xumm And this log is right?
                $ dmesg | grep veye
                [ 26.415448] veyecam: loading out-of-tree module taints kernel.
                [ 26.418410] veyecam 9-003b: probing v4l2 sensor
                [ 26.418573] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
                [ 26.430446] veyecam 9-003b: probe failed VEYECAM_MODEL_ID_ADDR
                [ 26.431893] veyecam 9-003b: board setup failed
                [ 26.433188] veyecam 10-003b: probing v4l2 sensor
                [ 26.433346] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
                [ 26.444597] veyecam 10-003b: camera id is veyecam
                [ 26.450485] veyecam 10-003b: sensor is IMX385
                [ 26.451703] veyecam 10-003b: board type is ONE board
                [ 26.453870] tegra-camrtc-capture-vi tegra-capture-vi: subdev veyecam 10-003b bound
                [ 26.458594] veyecam 10-003b: Detected VEYECAM sensor
                  Yes, the board have 2 mipi csi interface ,you connect just one camera.
                  • M
                    @veye_xumm I have posted this matter at the nvidia forum site.
                    https://forums.developer.nvidia.com/t/xavier-nx-with-jetpack5-01dp-cant-play-veye-mipi-imx385-camera/223524
                    • M
                      @veye_xumm By any chance, does the IMX385 camera firmware version matter?
                        I do not think so.
                        • M
                          @veye_xumm NVIDIA has replied, but I don't know the meaning...
                          Pls explain what they say...
                          **Please collect the trace log to check.
                          Also be aware below for r35 release.
                          Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
                          An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
                          You can calculate the output data rate with the following equation:**
                          https://elinux.org/Jetson/l4t/Camera_BringUp
                            @maponarooo
                            • M
                                @maponarooo
                                • M
                                  alt text
                                  alt text
                                  Caught SIGSEGV
                                  Waiting for EOS...
                                  What do I do?
                                    @maponarooo
                                    Please try
                                    dmesg
                                    check if any errors.
                                    • M
                                      What's the matter?
                                      $dmesg
                                      [ 22.356665] handlers:
                                        @maponarooo
                                        • M
                                          Caught SIGSEGV
                                          Waiting for EOS...
                                          After, dmesg logs....
                                          $dmesg
                                          [ 153.865630] Call trace:
                                          quad@quad-nx:~$
                                            @maponarooo
                                            Here is my suggestion that
